#Camaro6
AWE Tuning
Old 12-02-2018, 10:05 AM   #1
cb2011rs
cb2011rs's Avatar
Drives: 2018 1SS 1LE
Humming before start up
Hello everybody it's good to be back I just picked up my brand new 2018 1 l e 1ss Camaro on Friday and I did notice this morning when I went out to start up the car that before I open the door or shall I say the minute I open the door a humming noise came from the back of the car sounded weird . I'm thinking normal operation because I'm not used to the car but I want to know if anybody else has heard any strange noises like this thank you in advance
cb2011rs is offline   Reply With Quote
Old 12-02-2018, 12:02 PM   #2
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
Better off recording it.
ItsChristianInHD is offline   Reply With Quote
Old 12-02-2018, 12:06 PM   #3
ChevyRules
Drives: 2021 Tesla Model 3 LR
It may be the low pressure fuel pump getting the system primed anticipating the car will be started.
ChevyRules is offline   Reply With Quote
Old 12-02-2018, 01:13 PM   #4
cb2011rs
cb2011rs's Avatar
It sounded like it was coming from that area . Everything seems normal and driving fine . I just found it a bit odd .
Old 12-02-2018, 01:16 PM   #5
Whocares05050
Drives: 2018 Camaro SS 1LE
Its just the fuel pump priming... happens every time you open the drivers door
Whocares05050 is offline   Reply With Quote
Old 12-02-2018, 01:57 PM   #6
cb2011rs
cb2011rs's Avatar
Thank you , I figured it was something like that but I am obviously not used to the little irks and quirks . i always try to post here before I freak out .
Once again , thank you for your helpful input .
Old 12-02-2018, 04:27 PM   #7
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Most likely it’s the fuel pump.
Azerlazer26 is offline   Reply With Quote
Old 12-02-2018, 04:41 PM   #8
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
If the noise stops after a few seconds, then (as others have said) it's the low pressure fuel pump priming.
For some reason it's louder in the SS than in the LT or any other car I have or had before.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 12-02-2018, 05:07 PM   #9
cb2011rs
cb2011rs's Avatar
Yes , it was pretty loud and it did stop after a few seconds .
Old 12-03-2018, 04:47 AM   #10
mdhopt36
Drives: '17- 1ag37 V6 traded, for 1SS 2018!
Same thing, mine sounds like a small electric motor, for about 1 second when the door is first opened.
mdhopt36 is offline   Reply With Quote
Old 12-03-2018, 01:05 PM   #11
HighIron
Drives: 2024 2SS Summit White
Well I'll be...
Always wondered what that noise was. I kept thinking it was the power seat moving....but then my 1SS doesn't have seat memory.
HighIron is offline   Reply With Quote
Old 12-03-2018, 05:52 PM   #12
Chevmaro
Chevmaro's Avatar
Drives: 2019 SS 1LE
I have had about 18 cars so far and have never heard this noise before-why the Camaro? Is it related to direct injection?
Chevmaro is offline   Reply With Quote
Old 12-03-2018, 06:18 PM   #13
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I would say yes. Plus that is also why these cars crank for a few seconds when cold as the mechanical high pressure fuel pump (cam driven and located at the back of the motor under the intake manifold) has to step up the pressure supplied by the fuel tank pump (400 psi - I think) to 2100-2200 psi. All this pressure is needed by those direct injectors so they can do their thing.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is offline   Reply With Quote
Old 12-04-2018, 10:52 AM   #14
MackSteelPrivateEye
Banned
Drives: 6 on the Flo' Super Sport
The car knows you are coming and primes the pump for your comfort and convenience to serve you better.
MackSteelPrivateEye is offline   Reply With Quote
