12-14-2017, 01:14 PM | #1 |
Drives: 2010 Chevy Camaro 2SS/RS Join Date: Jan 2015
Driveshaft Hits Heatshield
I’ve got a 2010 Camaro SS with a one piece aluminum driveshaft from DSS. Lately I’ve been having issues with the driveshaft rubbing hard on the heatshield. The first time it happened, I took the car back to my shop to have them adjust the heatshield so it doesn’t hit. Worked for a few weeks and then it did it again but it seemed to be caused by pulling out of a driveway with a steep incline that I took at an angle. So my thought is that since I have removed the front sway bar, taking the steep driveway at an angle allowed to car to flex causing the driveshaft to rub on the heatshield (and continue to rub the following 5ish miles home ).
Got the car home, put it up on jackstands and got under her. I basically unbolted the heatshield, drilled the mounting holes out some, added a washer to each one and bolted it back on as tight as I reasonably could. Told the shop about it, they ordered some subframe connectors, cradle and diff bushings that we think will solve the issue. Well today, on the way home from work, I had some open highway and had a little fun with a good hit of the skinny pedal. Low and behold, the driveshaft is hitting the heatshield again, only not as bad as the previous two times. Not yet at least. So my questions are, has anyone had a similar issue and does anyone have any further suggestions/ideas?
2010 Camaro 2SS
2010 Jeep Wrangler 2014 Ducati 1199 Panigale S |
12-14-2017, 01:32 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
I have a DSS carbon fiber ds. My shield was very close to it and I just took it off. I also wrapped my exhaust with header wrap to cut down on radiant heat.
12-14-2017, 02:56 PM | #3 |
Drives: 14 SS/ 1LE Join Date: Jun 2013
Just take the heatshield out
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers |
12-14-2017, 03:26 PM | #4 | |
2010 Camaro 2SS
12-16-2017, 02:54 AM | #5 |
Search on here, most if not all people with 1 pieces don't have the heat shield and don't have problems
2014 1SS/1LE
12-26-2017, 07:03 PM | #6 |
So I’m going to bump this thread up for a little more help on this issue.
I got the heatshield off and went to bolt the driveshaft back up in place but it seems as though the cables for the ebrake that run right below the gas tank/above the driveshaft are sitting right on top of the driveshaft. So as the driveshaft turns its going to start wearing on that cable real quick. There are white clips on the bottom of the gas tank that are supposed to hold the ebrake cables but the cables don’t stay in them, they pop right back out. I’m looking for ideas as to how I can secure the cables up and away from the driveshaft yoke. There’s nowhere to zip tie it up nor to be able to drill into.
2010 Camaro 2SS
12-26-2017, 07:58 PM | #7 |
I used looooong zip ties to tie the cables back. They need to be long to reach far enough back to somewhere you can loop them through. I think they are 18" or so. I got the longest ones Harbor Freight sold.
12-26-2017, 08:03 PM | #8 |
That’s what I was thinking about doing but didn’t see anywhere to zip tie them to. What did you zip tie around?
2010 Camaro 2SS
12-26-2017, 08:44 PM | #9 |
I can't remember exactly but there are some stationary "structures" near the fuel tank you can go around or through.
03-28-2022, 09:53 PM | #10 | |
Drives: 2010 Camaro SS Join Date: Aug 2018
03-29-2022, 06:52 PM | #11 |
His post was 5 years ago, not sure if he even is still on here, but could be. I installed a 3.5 inch dia 1 pc aluminum drive shaft in my Camaro and it was hitting the heat shield, so I just removed it! No heat issues thus far. Done a year ago. You could always bend it upwards some for clearance since they are so "flimsey" and they do bend easily, just push it up a bit where you think it is hitting. Good luck..
04-19-2022, 02:12 PM | #12 |
Drives: 2013 Camaro 2SS/1LE Join Date: Jan 2022
Just did BMR suspension, drag pack, and one piece dss. Now I’m having the issue with the ebrake popping out of the clips and rubbing against the drive shaft causing a terrible noise. Fix actions? Nowhere to zip tie… frustrated!
04-19-2022, 03:14 PM | #13 |
I for one, never had THAT issue to deal with.
