10-22-2013, 05:52 PM | #1 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
Burping the coolant system?
First off, I don't run Dexcool. Only water + RMI-25 which was worked well for me over the years in my Grand National.
Prior to the Camaro, I had an SSR (LS-2) that had all sorts of coolant ports that could be opened to bleed off any air in the system. I do not see these ports on the LS-3. There is something on the water jacket, but I don't think it has anything to do with bleeding the system. Anyhow, I took out my thermostat completely today because I have these sudden temperature spikes if the car is moving too slowly. Both fans are certainly blowing and I still have the factory settings for the temperatures (but may have the fans programmed as the wrong type). Even w/o the thermostat and 80+ degrees out, the car was right around 212 on the highway, and more like 225 at idle. I blew off some steam via the overflow hose. I did this a few times, and now it seems to be staying right around 200 (no A/C, no thermostat). Any useful tips on getting ALL the air out of the coolant system?
Jack Bilger
10-23-2013, 05:44 AM | #2 | |
The Thermostat only sets the Lowest Temp the engine will run. The Radiator and Fan Settings are what control the High number. A custom tune turns the fans on at a lower temp to control the operating temperature. I don't believe you can run this engine without a thermostat as it controls the flow through different passages.
www.jannettyracing.com
