Old 03-08-2013, 07:24 PM   #1
montel
montel's Avatar
Drives: dont have 1 YET
4th gen v6 0r v8 help
Hey everybody I just got a job and saw a bEAUtiful 4th gen camaro, and well idk if ts a v8 or v6, but if its a v6 wat can I do to make it faster.
montel is offline   Reply With Quote
Old 03-08-2013, 07:30 PM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Put a V8 in it
There are 3800 guys on here, so I'm sure they can point you in the right direction
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 03-08-2013, 07:44 PM   #3
montel
montel's Avatar
Want that cost a lot
Old 03-08-2013, 08:00 PM   #4
fbodyrs96
fbodyrs96's Avatar
Drives: 1996 Camaro RS convertible
Either way it's not cheap.
fbodyrs96 is offline   Reply With Quote
Old 03-08-2013, 08:02 PM   #5
montel
montel's Avatar
Wer would I find a ss engine and also wat bout handling wat r some good cheap mods
Old 03-08-2013, 10:25 PM   #6
insidethreat07
insidethreat07's Avatar
Drives: 2001 Camaro 3.8
In all honesty if it a v6 its still a reliable motor. I have a 01 v6 and love it. I wouldn't do a ls1 swap. It would be cheaper and overall easier to sell the v6 and buy an ls1 car. If performance is what you after go for an ls1. If you don't have the $$ for the ls1, the l36 is still a fun nice little motor. Can still do donuts and burnouts. Just depends what your looking for. If its a v6 and has a y87 rpo code that means it has a sports package. Didn't make a allot of y87.
2001 Camaro V6
2016 Camaro 2SS
insidethreat07 is offline   Reply With Quote
Old 03-08-2013, 10:27 PM   #7
insidethreat07
Any pics of said car. I can probably tell just by the pics
2001 Camaro V6
2016 Camaro 2SS
Old 03-09-2013, 06:11 AM   #8
montel
montel's Avatar
Thanks a lot ill try to get pics
Insidethethread wat did you do to your car
Old 03-09-2013, 07:37 AM   #9
fbodyrs96
fbodyrs96's Avatar
Since you asked Derek, I have all the bolt on s, most of the suspension and a bigger cam.
Old 03-09-2013, 07:44 AM   #10
montel
montel's Avatar
I might sound stupid but what is bolt ons and wat do they do
Old 03-09-2013, 07:44 AM   #11
montel
montel's Avatar
Wats a cam
Old 03-09-2013, 11:17 AM   #12
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Originally Posted by montel View Post
Wats a cam
No offense but it sounds like you should do a lot of reading before you do any kind of work to your car.
Cam is short for camshaft which opens and closes the valves in the cylinder heads to allow in the fuel/air mix and then lets out the exhaust gases. To meet emissions standards, factory cams leave a lot of performance untapped and swapping cams is a good way to get some extra horsepower. But, factory engines are designed so that each piece works together perfectly, so depending on the cam you choose, it may not just be a direct swap. You may have to change out some other parts.
Bhobbs is offline   Reply With Quote
Old 03-09-2013, 11:21 AM   #13
montel
montel's Avatar
Ok thanks yea ik I need to learn more bout the the 4th gen
Old 03-10-2013, 09:12 AM   #14
xXSilencerXx
Butter Bar!
xXSilencerXx's Avatar
Drives: 2011 SS, 1998 Trans Am
If you want torque and a car comparable to your 5th gen, you'll want the V8. If you want a car to put around in and occasionally have fun and not car about outright speed go with the V6.
You need to learn more about basic motor work on any car.
http://auto.howstuffworks.com/camshaft1.htm
That'll give you a very basic understanding of the various camshaft configurations. All the recent Chevy V8's are pushrod motors, the northstar V8's were DOHC if I recall correctly and the LT5 was.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension
2004 GSXR 1k, Matt Mladin Edition
xXSilencerXx is offline   Reply With Quote
