07-04-2015, 10:42 AM | #1 |
Drives: 2006 Z51 Join Date: Nov 2013
CAN USE SOME HELP! 1ST TRIP TO TRACK
Need some help here guys!Now in my defense I was operating off of about 3 hours of sleep and had worked from 7 a.m.to 6:30 p.m. and then straight to the track!
To say the least I felt like I was in a cloud of fog.However I have been waiting all year to get the car to the track and perform a shake down to see where this thing was at.Now my excused are out of the way. I AM LOOKING FOR HELP TO IMPROVE MY PERFORMANCE AT THE TRACK!! When I headed to the track I let my buddy know that I wanted to run at least a 10.8 last night.LOL, well that did not happen!Here are a list of all of my 5 runs in line.The last 2 runs were ran one after the other(hot lapped). PLEASE DO NOT LAUGH TOO HARD ON THI FIRST RUN, I WAS ASKED BY A COUPLE OF PEOPLE DID I TAKE A KNAP AT THE TREE: Oh yes, I have to add one more excuse- I was afraid of breaking my rear end so I did start off in 2nd gear.By the way Happy 4th of July to you all! :-) 1st Pass: reaction-1.23 60 foot-3.13 (spinning 1-3 gear) 1/8 mile- 96.17 1/4 mile- 106.94 1/4 ET-13.74 (SMOKING QUICK) 2nd Pass: reaction-0.94 60 foot-2.79 (I SEE IMPROVENT) 1/8 mile- 96.71 1/4 mile- 118.64< I THINK I AM READY FOR CAMARO FEST> 1/4 ET-13.002 AT THIS POINT I WAS TOLD BY MY BUDDY THAT HE HOPES I CAN JUST GET INTO THE 11'S (PISSED ME OFF- SO I DECIDED TO START IN 1ST GEAR WITH A SOFT LAUNCH) 3rd Pass: reaction-1.07 60 foot-2.21 (spinning) 1/8 mile- 99.62 1/4 mile-125.42 1/4 ET - 11.752(THIS PASS SHIFTING INTO 3RD GEAR EXHAUST SEPARATED ON PASSENGER SIDE A HIT GROUND) 4th Pass: reaction- .091 60 foot-1.92(I WAS TOLD TO LOWER TIRE PRESSURE, WENT FROM 32-18 PSI BEFORE THIS PASS) 1/8 mile- 99.93 1/4 mile- 124.52 1/4 ET-11.454 The track was closing so I just did a hot lap for my final run.i am running Hoosier DR's on the car 5th Pass: reaction; red light I guess -0.169 60 foot- 2.24 1/8 mile- 100.33 1/4 mile- 128.42 1/4 ET -10.982 (THIS PASS I HELD MY RPM'S UP TO ABOUT 25 TO 2800 RPM'S ON LAUNCH AND HAD NO TIRE SPINN AT ALL, IT PULLUED THE FRONT END AND HOOKED GOOD. I DID HOWEVER SHIFT INTO 4TH GEAR BEFORE THE TRAPS AND SLOWED DOWN A TAD BIT). I DO PLAN ON INSTALLING MY ZL1 CENTER AND DSS D.S. ANDAXLES IN A COUPLE OF WEEKS.I WILL NOT REVISIT THE TRACK UNTIL THEN. ALL HELP AND SUGGESTIONS ARE VERY WELCOME. |
07-04-2015, 02:02 PM | #2 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
How much power u make? 10.9@128 with a not so good 2.2 60' is pretty fast. U just need some more practice launching.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
07-04-2015, 10:49 PM | #3 | |
EVERY PASS I WAS SHIFTING INTO 4TH GEAR AND I COULD FEEL THE CAR SLOW DONW. |
07-04-2015, 11:07 PM | #4 |
I STRUGGLED GETTING THE RPM'S UP AND NOT MOVING FORWARD TOO MUCH! I AM USE TO DRIVING AN AUTOMATIC AND THE MANUAL IS A LOT DIFFERENT!
07-05-2015, 08:46 AM | #5 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
Are you driving a vette?
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
07-05-2015, 11:43 AM | #6 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
If your trying for a good run and ET don't worry about the reaction time concentrate on the launch and leave when your ready.
07-06-2015, 05:57 PM | #7 |
07-06-2015, 06:01 PM | #8 |
THANKS, THAT IS WHAT I PLAN ON DOING THE NEXT TIME I GO TO THE TRACK. I WAS JUST DOING TOO MUCH THINKING AND TRYING TO MONITOR ALL MY GAUGES AND WHAT NOT INSTEAD OF CONCENTRATING ON DRIVING.
07-07-2015, 02:33 PM | #9 |
My tuner thinks that there is a problem causeing the computer to pull timing out of the car. He said I should be somewhere around 135-144 for my trap speed. Now I am not sure what to think here.?!
07-07-2015, 04:10 PM | #10 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
It would help if you told us all your setup
07-07-2015, 11:26 PM | #11 |
I have a forged bottom end LS3 with stock heads, intake and TB. The car has the Eliminator Fuel pump, 1300 injectors, comp cam blower cam with a F1a blower making about 12 pounds of boost. Also have the Alky meth system dual nozzle . Trans has a replacement clutch in it also.
As far a suspension does a drive shaft loop count? and replacement bushing for the stock rear. That is the list of mods done to the car as of now. Running on the 325/45/18 DR-2 by Hoosier out back and 255/50 R18's up front! |
