07-24-2011, 02:37 PM | #1 |
Synergy Green <3
Drives: 2010 Synergy Green Camaro Join Date: Aug 2010
Need Help!
As i was driving home today i noticed that on my digital speedometer it said "Battery Saver Active." Is this something i should be worried about?
Join my group! "Young Camaro Owners"
07-24-2011, 02:45 PM | #2 |
knows 2 facts about ducks
You might have a slow drain on your battery. Have you done any electrical work recently?
07-24-2011, 02:46 PM | #3 |
movin' down the motorway
Drives: Summiit White 2SS/RS/M6 Join Date: Feb 2010
did a quick google search and found this...
"The battery saver light is activated when the PCM module detects low battery output or charging system output."
417 stroker - Florida Speed and Power
07-24-2011, 02:48 PM | #4 |
Synergy Green <3
No thats why im so confused, about 2 months ago i got a new battery but that was the last thing i did to it.
07-24-2011, 02:50 PM | #5 |
Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
how many volts is the alternator putting out. it may be going out.
07-24-2011, 02:51 PM | #6 |
Do you have subs and a amp.
07-24-2011, 02:52 PM | #7 |
Synergy Green <3
nope, but i keep my music at about 20 volume, (which probably isn't good) and to save battery i turned my headlights off
07-24-2011, 03:02 PM | #8 |
Drives: 2006 Silverado SS, 2009 G8 GT Join Date: Aug 2008
Sounds like you may want to have the battery and/or Alternator checked. This is straight out of the owners manual....
Battery Voltage and Charging Messages BATTERY SAVER ACTIVE This message displays when the vehicle has detected that the battery voltage is dropping beyond a reasonable point. The battery saver system starts reducing certain features of the vehicle that you may be able to notice. At the point that features are disabled, this message is displayed. It means that the vehicle is trying to save the charge in the battery. Turn off unnecessary accessories to allow the battery to recharge. http://www.chevrolet.com/assets/pdf/...aro_owners.pdf PG 5-34 |
