08-22-2013, 09:52 PM | #1 |
Drives: 2010 Camaro V6 Join Date: Mar 2013
Subwoofer turns off if you go past half volume
Rockford Fosgate P300-10 turns off when ever I go past 25 volume. If I the volume stays on around 1-25 it stays on but once past 25 it turns off. Anyone got any suggestions to what could be wrong?
08-22-2013, 10:00 PM | #2 |
Drives: 2010 Camaro 2SS/RS RJT, 6speed Join Date: May 2011
What's the gauge power and ground wires you are running? It the ground a proper ground? Is the voltage fluctuating?
2010 Camaro 2SS/RS, LS3 - 6 speed. Mods, Magnaflow exhaust with resonator delete. ******** 12" stealth box subwoofer kit, Kicker 400 mono amp, JL XD 400/4 amp.
08-22-2013, 10:02 PM | #3 |
Drives: 2010 2SSRS black, 03 Blue SSS Join Date: Jan 2013
You sure the amp going to it isn't tripping into protect mode and cutting off?
08-22-2013, 10:09 PM | #4 |
08-22-2013, 10:11 PM | #5 |
08-22-2013, 10:14 PM | #6 |
Drives: 2018 1LE Join Date: Feb 2013
If your amp is going I to to p mode gain to high or Bad coil sub could also be bottoming out Also are you use a loc for a high low
08-22-2013, 10:20 PM | #7 |
08-23-2013, 01:41 PM | #8 |
The loc might be out of adjustment (set to high) see if turning it down might help
