07-11-2014, 04:43 PM | #1 |
Drives: Inferno Orange 2013 LT2-RS Join Date: Aug 2012
Check Left Rear Signal Light
I've been getting the above msg on my DIC occasionally, but when I check the turn signal it's working. Should I be worried about this or do I need to let the dealer check it out?
Leon in beautiful downtown Grand Prairie, TX
2013 IOM LT2/RS, American Racing Daytona Wheels,Factory Ground Effects, LED Tail Lights,FlowMaster's, Stripe Package. |
07-11-2014, 04:57 PM | #2 |
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD Join Date: May 2013
One of your filaments is failing on one of your rear bulbs. If you buy a package, two come in it. Replace both
2014 CTS-V... with some go-fast bits coming
07-11-2014, 08:39 PM | #3 |
CocoaKid
DONT go to the dealer. I got the same last month, I changed them myself outside the Auto Parts store. Its so easy to do, easy to the point if you go to the dealership you're wasting your time. I don't even think you need tools.
07-11-2014, 08:52 PM | #4 |
It is super simple to do. You will have to pull the 3 plastic rivets (I guess)? and then it is just a simple twist and pull.
07-11-2014, 08:59 PM | #5 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
You just need a 1/4 in flat blade screw driver. left the small one out first the the large one.
Caddy
07-11-2014, 09:03 PM | #6 |
Drives: 45th SS, '12 ducati 1199 on order Join Date: Mar 2012
You're running low on blinker fluid. You need to top it off.
07-11-2014, 09:16 PM | #7 |
Lol invade!
07-11-2014, 09:21 PM | #8 |
Drives: 2010 rs 2lt Join Date: Aug 2012
My bulbs have a issue also, Have replaced 3x already , just change it yourself
