09-26-2023, 12:52 PM | #1 |
Drives: 2016 Chevy Camaro 2SS Join Date: Sep 2023
Wheel & Tire Fitment
Hey everyone! I just picked up a 2016 Camaro 2SS with 6k miles about a month ago and am loving the car. My only issue is it currently has 22” rims with low profile summer tires on it which rub a little when turning hard and aren’t the best for ride quality.
I am looking to do a 20” square setup but have never bought aftermarket wheels so I’m not sure what will fit and I’m afraid of making an expensive mistake. I’m looking at 20x9 +38 offset all around but I’m getting mixed opinions as to whether this will fit in the front on a 275/35/20 tire. Any and all input is appreciated! Looking for no rubbing scraping or any issues. Thanks. -Matt |
09-26-2023, 12:57 PM | #2 |
Monterey County Camaros
If your running a 275 front you should go with a 20x9.5 or a 20x10. The 9" is too small.
I currently run a 275/35r20 on the fronts and 305/30/r20 on the rears with 5mm spacers all around. No issues with rubbing.
Follow us on Instagram @montereycountycamaros
09-26-2023, 01:00 PM | #3 |
Got it, I’ll look into that thank you! The main confusion for me is offsets as I’m not sure what will fit. Is there a range I should be looking for that is safe to fit in front and rear?
09-28-2023, 08:12 PM | #4 |
Drives: Angry Dorothy II 2016 2SS Join Date: Aug 2009
looking for 2 rear zl1 wheels.
thanks. |
09-29-2023, 01:48 PM | #5 |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
You don't need spacers with 305/30r20 on the back
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
09-29-2023, 01:52 PM | #6 | |
Front offset for 1le sizes is 20mm https://www.wheel-size.com/size/chevrolet/camaro/2020/ 2016 uses same offsets as 2020. Even non 1le use same offsets. Range tolerance is about (2mm to 4mm?) from numbers I provided. Front offset has to be correct for 6 piston brakes. 4 piston has no issue with 1le numbers. I would recommend a 19" square setup. Rather than 20" because it gives more options and availability for high performance tires and cheaper prices. Check Apex site for square setup numbers
09-29-2023, 02:09 PM | #7 |
Like the slightly wider look plus it corrects the rear offset from 43 to 38
10-01-2023, 06:33 PM | #8 | |
10-01-2023, 06:47 PM | #9 |
I didn't need them either. Preferred them though. At 5mm all around it gave me that peace of mind the front tires won't rub the wheel well or that off chance I could damage the driver side rear harness (even though I did relocate it). And 5mm still gives me 9 full turns on the lugs and as hard as I push the car I haven't had any issues.
10-01-2023, 06:51 PM | #10 | |
Tags |
fitment, rubbing, square, wheels and tires |
