05-02-2012, 09:44 PM | #1 |
Drives: Camaro 2010 SS supercharged(magna) Join Date: Jan 2012
transmission flush when?
Hey guys - at what mileage should the camaro be at before tranny flush?
05-02-2012, 10:46 PM | #2 |
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS Join Date: Apr 2012
Dont quote me on this but if im not mistaken the tranny is sealed and good for 100k miles before service.
05-02-2012, 10:52 PM | #3 |
thanks for post!
05-02-2012, 11:03 PM | #4 |
Mechanical Engineer
Drives: 2012 IBM Camaro 2SS/RS A6 Join Date: Oct 2008
Unless you flush at regular intervals from the start, flushing is seriously bad for your transmission. Best to drain and refill at the manufacturer's recommended milestones, not flush.
Current Vehicle: 2012 Chevrolet Camaro SS
Past Vehicle: 2001 Honda Prelude SS LEFT HAND DRIVE |
05-03-2012, 02:09 AM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
No flushy, no!
Change fliud at 10k or so.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
05-03-2012, 02:20 AM | #6 | |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
They ended up paying 90 percent of the cost to replace it.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
05-03-2012, 05:47 AM | #7 |
Drives: 2010 2SS/RS JFB Join Date: Mar 2012
05-03-2012, 08:50 AM | #8 | ||
Drives: 2SS/RS Join Date: Sep 2008
Never flush a tranny unless you are rebuilding it. Just change the fluids. Also the auto is sealed and GM recommends it not be changed. |
05-03-2012, 09:12 AM | #9 |
Resident Engineer
Drives: 2010 Camaro SS, 1988 GMC S-15 Join Date: Jun 2009
I took mine to the dealer for trans service (i have 60k on my odo) and my buddy at the service counter looked at me like i'm stupid and said it should be done at 100k. So i saved myself a nice chunk of change.
12.68 @ 109: LSR cai, Borla S-type axle-back, Tunes |
05-03-2012, 10:32 PM | #10 |
Drives: 2013 Fiat 500 Abarth Grigio Join Date: Apr 2011
U cant change the fluid with out flushing since most of the fluid is in the tq converter and only about 6 or 7 quarts are in the the tranny itself. I had mine flushed and the fluid switched to amsoil about a month ago and the tranny shifts better and i have no problems to speak of.
05-04-2012, 12:49 PM | #11 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
I'll regurgitate what I posted less than a month ago about the same question asked.
Negative on going with a flush, but a fluid exchange is fine. Yes, there is a difference in the methods especially if the style of flush is the back flush method. A back flush can dislodge debris that can cause problems with the valve body. The pan should always be dropped and the filter should be changed even though it is nothing more than a felt screen. After that, just top off with fresh fluid. Fluid choice is up to you as long as it meets the Dex6 requirement. If a dealer tells you that a "flush" is the latest and greatest "great" thing, then they are lying and only trying to get extra money out of you. Dex6 is light years ahead of Dex3. Too bad it took GM so long to finally figure that out. Using a boutique Dex6 approved tranny fluid is a waste of money IMO. Any off the shelf Dex6 GM licensed manufacturer is all that would ever be needed. Even though GM is proud of their extended tranny fluid change intervals using Dex6, I would not go more than 50,000 miles even in a non severe service. If it is severe service, I would change it every 30,000 miles. The 6l80e holds just a tad over 12qts of fluid when bone dry.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
