Old 01-03-2017, 12:36 PM   #1
SSpade22
SSpade22's Avatar
Drives: 2010 Camaro SS (Twin Turno 418)
New TT set up almost done!
Almost finished with my custom TT set up, I really have no idea what to expect when it comes to power.
I’m still going to be using my built 418 engine running E85, but instead of a Procharger F1-R (previous set up) I’m getting a custom Twin 53 set up made for the car. I made just about 1000 to the wheels and was able to break into the 5s (1/8th) with the Procharger. Needless to say I’m excited about what the results will be with this set up!
https://www.youtube.com/channel/UCsPUas9w7owlCJZffwvl-4Q
Engine Modifications:
TSP 418 w/ 4 in. Stroke Custom cam
Power-gilde transmision
LSA WCCH Ported Heads 1400hp Axle Shafts DSS
FORE Dual pump FIC 2000cc Injectors
Twin Garrett 53s
SSpade22 is offline   Reply With Quote
Old 01-03-2017, 12:52 PM   #2
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Looking good!!
camarosspower is offline   Reply With Quote
Old 01-03-2017, 01:00 PM   #3
mrimpala02
Drives: Black 2SS RS w/White Stripes
Nice! The exhaust exits are very cool! What fuel system are you running? I wouldn't think a boosted ZL1 fuel pump could support your previous power setup, right?
Also what hood is that? Got any more pics? I'm looking for a different hood. Thanks.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 01-03-2017, 01:05 PM   #4
SSpade22
SSpade22's Avatar
You're right, I should edit my signature lol. I'm running a boosted FORE dual hat set up.
and here is a different picture of the hood. Its a VIS CF hood.
Twin Garrett 53s
Old 01-03-2017, 01:36 PM   #5
mrimpala02
LOL! Cool!
Very sharp looking! How do you like the fitment of the hood? I know most places suggest hood pins with their aftermarket hoods, but you think they are necessary? Sorry for being off topic.
Old 01-03-2017, 02:11 PM   #6
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
i run the VIS CF hood, fitment is perfect
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
Old 01-03-2017, 02:53 PM   #7
HorsePowerAddicts
HorsePowerAddicts's Avatar
Drives: LSx Powered
Awesome looking setup. Any reason for going small on the turbos? We have a 418/powerglide setup running twin t4 76's and they come in by 4000 rpms and have no problem making 13 psi on the trans brake almost instantly.
HorsePowerAddicts is offline   Reply With Quote
Old 01-03-2017, 03:47 PM   #8
SSpade22
SSpade22's Avatar
My horsepower goal wasn't high enough to require turbos that big, how much hp is your 418 standing up to (and what fuel)? Ive seen so many different people saying 1200-1500, wondering what your feedback is.
Twin Garrett 53s
Old 01-03-2017, 08:54 PM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Im not a 418, and I don't know what the extra cubes are worth in power, but here is a graph of my car and what it made at rpm, vs boost. ***EDIT sorry I thought it had the boost psi on it, It was at 13.5psi***
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 01-03-2017, 08:58 PM   #10
1KillerSS
1KillerSS's Avatar
The three runs were the three settings of my boost controller. Off A, and B. The B setting was 13.5psi I can't remember what springs are in it, and what the A setting is set at, its been soo long since I've had the car on the road.
Build thread
Old 01-03-2017, 09:05 PM   #11
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
Badass! Love the exhaust.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 01-04-2017, 07:35 AM   #12
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Looks cool!.......... hope you don't ever have to pull up next to anybody on the street
Irnwkrkev is offline   Reply With Quote
Old 01-04-2017, 09:04 AM   #13
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
What seats are you using?
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 01-06-2017, 03:31 PM   #14
SSpade22
SSpade22's Avatar
Oh i will be, cause street car lol
Twin Garrett 53s
