03-07-2024, 12:51 PM | #1 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
Oil filter confusion
I couldn't get the search page to load. I got an AC Delco PF64 oil filter from Amazon. On the filter is #12706595. When I did a look up for AC Delco, the
PF 64 # is 19386865. What gives?
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
03-07-2024, 12:57 PM | #2 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
There's been updates to the PF64. As long as it says PF64 it's good. The PF64 I have is 25206377!
No worries, send it!
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
03-07-2024, 01:44 PM | #3 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
GM changes the PF64 filter more frequently than one changes their underwear. I am aware of at least two "update streams", see below, the final SKUs of which (25206377, 19419226) are both marked as available:
12640445 -> 12696048 -> 12706595 -> 25206377 19386865 -> 19419226 No idea what the differences among them, if any, are, I suspect supplier changes and the use of ever cheaper materials. I loved the original 12640445 filter, by the way, it was sturdier, thicker and looked more robust. Last oil change I used an Amsoil filter (EA15K50) along with their oil. Yes, I know it's 3x more expensive than these ACDelco filters, but boy, does it look and feel way more solid, and at $5 vs $15, nobody cares about the higher price (let the flame war begin ).
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
03-07-2024, 02:14 PM | #4 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
As long as you have close to a 22 psi bypass rating for the filter any quality brand will be ok.
03-07-2024, 02:22 PM | #5 | |
Petro-sexual
I am doing something similar. I started (last oil change) using their oil and filters in their service kit (for lack of a better term), instead of the Mobil oil and Delco filter I was using.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
03-07-2024, 02:26 PM | #6 |
Thanks guys. This is crazy. Isn't there also a "longer" version of the PF64. UPF64R??
Mal
03-07-2024, 02:29 PM | #7 |
On another note, I'm having myM6 fluid changed today. What is the reason for the level to be 1/8 below rather than at the bottom of the fill hole?
Mal
03-07-2024, 02:30 PM | #8 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
More is not always better
Yeah but you certainly don't want a UPF64R (35psi bypass) and probably also don't want to dangle any precious bit of engine kit down below the pan where the speedbumps et al will remove the end of it in an unscheduled and violent fashion.
03-07-2024, 04:03 PM | #9 | |
Drives: 2017 Camaro ZL1 Join Date: Feb 2024
03-07-2024, 09:22 PM | #10 | |
03-08-2024, 09:31 PM | #11 |
Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
This might help, this is the official GM communication:
https://gmserviceinsights.com/new-ac...d-performance/ |
03-08-2024, 10:09 PM | #12 |
Drives: '20 ZLE Join Date: Jun 2020
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
03-09-2024, 10:07 AM | #13 |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
The Wix WL10290XP oil filter is well made and has the correct bypass (22) PSI for the LT4 engine.
Added bonus: it's painted black to match my car! |
