02-10-2010, 09:27 AM | #1 |
Emerald Coast Camaros
A question about cylinder heads
I am getting the SS with the Automatic transmittion. I know this is the L99 enigne. So here is the question. What heads are on this engine?
L92?? (if thats a head number) or what. And since I am thinking about porting and polishing or just replacing them with some high flow heads...I need a good place to get them. Thanks
Had: 69' RS, 78' Z28, 98' SS Have: 2010 1RS/SS |
02-10-2010, 09:36 AM | #2 |
Drives: 2010 Camaro 69 Nova Join Date: Oct 2008
Those heads would be the same as the LS3. The L92 and the L76 as well as the LS3 share the same castings. The difference would be in the intake valve and the valve springs.
The LS3 and I believe the L99 share a hollow stem intake valve. The LS3 uses the yellow spring good to .570" of lift. I think that the L99 uses the same spring. Robin
Holley Performance Products
02-10-2010, 10:23 AM | #3 |
thanks man
02-10-2010, 08:04 PM | #4 |
Drives: 2010 2SS IMB LS3/M6 Join Date: Jul 2009
I'm not sure if the L99 has hallow valve stems (sodium backfilled) like the LS3. I know the redline is less than the LS3 (6200 vs. 6600) but not sure if that has more to do with VVT or cam profile or lack of hallow stems. I have read the LS3 and L99 use the exact same casting and that casting is similar to but not identical to that used on the L92. I think the exhaust port openings are bigger on LS3/L99 applications. Before spending a bunch on aftermarket heads I'd recommend talking to a good tuner or builder about porting the heads. They already have great flow numbers.
2010 2SS LS3/M6 Imperial Blue
650HP LPE Package - 576.3 RWHP, 91-tune 4.10 Richmond Gears ZR1 Clutch / LPE Flywheel LPE IBM Coil Covers Thorley Shorty Headers Borla 140280 Cat-back ADM Boost Gauge MTI Shifter Hotchkis Sway Bars LPE Floor Mats SRP Heel-Toe Pedals |
02-10-2010, 09:49 PM | #5 |
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
CNC porting of the stock heads will do you just fine.
02-24-2010, 09:19 AM | #6 |
I think thats what I am going to do. I understand the HP gain is upwords to 120 HP.
Does that sound right? I know I did my 78 Z28 and gained close to 150 hp, but that had bigger valves too.
02-24-2010, 09:26 AM | #7 | |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
Texas Speed had some very reasonable heads for like 1K that give you 20-25 hp and Mast Motorsports has some 12 degree heads for $3,000 that came 45+.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
02-24-2010, 10:29 AM | #8 |
Drives: Camaro Join Date: Apr 2009
We are working on a aftermarket casting LS3 head, but it's a long way away right now. :( Currently we're cnc porting customers factory heads for right around $800.
02-24-2010, 10:32 AM | #9 |
Drives: Hoopty Winter Beater Join Date: Jul 2009
02-26-2010, 10:40 PM | #10 | |
Reher Morrison Racing
Drives: Inferno Orange SS/RS Join Date: Jul 2009
http://www.camaro5.com/forums/showth...t=42255&page=2
2010 Camaro SS/RS IOM, 475rwhp 415ft/lbs Cam-232°/245° .612 .612 113LSA. Precision 3500 stall, New Era CAI. Reher Morrison Heads, Manifold and TB. Ferrea H-stems, dual springs, Ti-retainers. American Racing long tubes-Xpipe, High flow CATs, "S"type Borla's. 160F Thermo.
VVT ACTIVE! Thanks to New Era Performance! -Induction R&D-EFI calibration Reher-Morrison Racing Engines http://www.rehermorrison.com/rmSale3.htm Phone 817-467-7171 cell 682-559-0321 |
03-01-2010, 09:32 AM | #11 | |
I guess I am trying to figure out if it is worth the extra cost. As it is right now this is what I am going to have done. Kooks Headers 1 7/8" tube Kooks High Flow Catalytic Converters Kooks Mufflers 3 inch High-Flow Stainless Steel Mid-Pipes Corsa Dual Rear Exit Exhaust System VARARAM or New Era CAI port and polish heads NKG Spark Plugs Retune I am looking to pick up at least 70 HP. Does that sound right?
03-03-2010, 12:38 PM | #12 |
See above
03-03-2010, 01:50 PM | #13 | |
Drives: Firehawk Join Date: Jun 2009
03-03-2010, 04:13 PM | #14 |
Drives: 2010 Camaro - BIW Join Date: Mar 2010
It's actually $750 to port and valve-job the LS3/L99 heads. Here's a link with some more info and flow data on the PRC heads including spring and valve options with pricing!
Let us know if we can help! http://www.texas-speed.com/shop/item...=1066&catid=20 Last edited by Lonnie@Texas-Speed; 03-05-2010 at 11:06 AM. |
Similar Threads | ||||
cylinder cut off question | camarokidz28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 08-24-2008 11:43 PM |
Cylinder heads | Stroker | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 06-05-2008 11:08 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
Gotta question bout my z28 | lm1power | Off-topic Discussions | 1 | 09-15-2006 02:58 PM |
