12-10-2012, 07:58 PM | #1 |
Drives: Black 2011 Camaro SS Join Date: Jul 2012
No oil pressure, sat overnight, now fine?
I drove my 2011 2SS for about 20 miles, we went into a restaurant for probable 20 minutes, came outside, cranked up my car and about 5 seconds later is reads no oil pressure turn engine off.
I cut the engine off, get out and look at the oil. Its full. The car has 11k miles on it. I cranked the car back up just to see. Same notification and about 2 seconds later the car started making a rattling noise coming from the engine. I shut the car off and called the dealership the next morning. I had it towed to the dealership. The said they couldn't find any problems. They ran it about 50 miles and it never would do it again. I have had it back for a week and put about 100 miles on it and it seems to be running ok. What could have done that? Why is it working now? My concern is...being out of town and the car doing this again and ill be stuck. The tech and the dealership said have it towed in again if it does it or just run it till the motor blows and they will replace it. He really seemed to share my concern about it doing it again but he said if the dealership can not duplicate the problem then they can not fix it. I guess they would rather not take my word for it and fix a $100 part and just let a 8k motor blow. |
12-11-2012, 07:12 AM | #2 |
Drives: Camaro SS & ZL1 Join Date: Sep 2011
The oil pump pickup could have stuck for a moment. There have been many folks here with stock oil pumps dying.
12-13-2012, 07:54 AM | #3 | |
Drives: GM Vehicles Join Date: Jun 2010
Please let us know if you end up having this concern again. We are here at your convenience if you have any questions or issues to address. Brandon Chevrolet Customer Service
12-13-2012, 08:38 AM | #4 |
Drives: 2015 c7 Join Date: Nov 2009
well keeping in my, replacing a oil pump cost around a grand at a dealership. mostly labor cost. but ya they wont fix something until its for sure broke lol,
12-13-2012, 01:32 PM | #5 |
Well between this and all the paint issues Ive been having Im seriously debating trading it in for something else. Makes me sick to my stomach having all these problems from a 40k+ car
12-13-2012, 01:33 PM | #6 |
The oil pressure at idle goes around 15PSI alot but other times it idles around 28PSI. Ive read a lot of other post stating around 28PSI is the norm. WHat could be causing this low oil pressure?
12-15-2012, 08:49 PM | #7 |
Drives: 2010 Camaro SS manual all stock Join Date: Jun 2012
I had same issue and the car was toed to dealer, the issues was the oil pump relief sticks due to a scratched bore, suggest you dig deeper in forums and find the tsb
01-09-2013, 06:23 PM | #8 |
Car just did it again. This time the engine is ticking really loud. Its obvious its not getting oil. I just hope when it gets towed tomorrow, it will do the same thing for the dealership. Ill keep this thread updated.
01-09-2013, 08:17 PM | #9 |
01-10-2013, 10:56 AM | #10 | |
Please send it all to my inbox. Brandon Chevrolet Customer Service
01-10-2013, 11:12 AM | #11 |
If the engine is gone...Ill be contacting GM, dont worry. I begged the dealership to replace the oil pump but No.....have to wait for the motor to blow and replace the 12k motor. Now I wont have a numbers matching car which is my biggest concern as I planned on passing this car down to my car and he hopefully keep it. Now Im wanting a buy back but I know that will not happen.
01-11-2013, 02:30 PM | #12 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Needs a new oil pump, pressure relief valve sticking. Don't drive it like that or it will need a complete engine. Dealer needs a refresher course in LS engine diagnosis and bulletin reading, that is one of the more common problems.
01-14-2013, 11:00 AM | #13 |
Oil pump was replaced this time. They had to call GM and they authorized it. SO now my car was ran without oil twice and they said no damage was done to the engine. They have absolutely no way of knowing that.
01-14-2013, 10:17 PM | #14 |
They should have taken your word the first time document it well and i would insist they send my #s matching block back to rebuilt .If it ever does it again.Imho
