Old 04-01-2015, 09:42 PM   #1
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Anyone check out the new MT ET Street R?
https://www.mickeythompsontires.com/...item=ETStreetR
Looks to be better than the ET street radial and almost as good as the ET street Pro. What looks promising for the 5th gen is two particular sizes. The 305/45R17 and 305/45R18 sound perfect for current 5th gen wheels like the new Race Star 17x9.5" and all the 18x9.5" choices. DOT legal radial construction as well so it can be driven to the track and back without worry.
Old 04-01-2015, 09:56 PM   #2
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
I wonder if they will stick better than the ET street II? They look almost like a slick, hard to believe it's street legal. Have fun driving in the rain with those lol.
Rico is offline   Reply With Quote
Old 04-01-2015, 10:22 PM   #3
VADER SS L99
Me personally I would only use them to drive to the track and back and maybe some late night grudge matches. Even then I would use caution as it seems the sidewall and compound are similar to the ET Street Pro. I'm sure someone will try to DD them but they should do so at their own peril. I'm pretty sure these will work better than the ET Street ll as far as straght line traction. The old ET Street tires are getting discontinued. I think they are making a new more daily driver friendly drag radial as well like the NT555R that will replace the old ET Street radial thats called the ET Street S/S.
Old 04-02-2015, 04:55 PM   #4
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Mine are on order for over a month
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 04-02-2015, 06:02 PM   #5
nyny69
Drives: 2010 IOM SS
I hope these are like the pro's. Those are the shit. Hurry up guys and get them. Im waiting on feedback before I pull the trigger
nyny69 is offline   Reply With Quote
Old 04-02-2015, 07:56 PM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
I loooooove my ET Pros!
Might try a pair once I'm done with these.
62nalide is offline   Reply With Quote
Old 04-02-2015, 07:57 PM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Im interested in feedback on these babies as well!
Rhino79 is offline   Reply With Quote
Old 04-02-2015, 09:10 PM   #8
smokum
smokum's Avatar
Drives: 2010 2ssrs
I was looking at these the other day
Will the 325/50/15's fit under these things ok. I was thinking about these because they are wider than the pro x 275's
smokum is offline   Reply With Quote
Old 04-03-2015, 04:17 AM   #9
VADER SS L99
If you notice the sizes you will see that its not made in the 275/60R15 size. Its because there is no reason. That size is reserved for the Pro tire. No need to try these in a different size if your Pro tires work well. My thinking is that these are so close to Pro performance and characteristics that there was no need to make it in the 275/60R15 size.
Also, something to note is that any sizes that don't follow the European metric sizing with a R in it are bias ply and NOT radials.
Old 04-03-2015, 09:36 AM   #10
Camaros & Coffee Norcal
Camaros & Coffee Norcal's Avatar
Drives: 2013 Camaro 1SS & 2015 Camaro SS
I spoke to mockey thompson this past weekend at the NMCA true street event. They said this tire is supposed to be better and hook better as it is made with the SAM concept of the pro in mind with a dot street lag radial. Basically took the pro and made it street legal. I'm due for a set of radials on my z06 18's so I'll be getting 305/45/18 here soon. Keep u posted
Camaros & Coffee Norcal is offline   Reply With Quote
Old 04-23-2015, 06:01 AM   #11
2010SSRSM6
2010SSRSM6's Avatar
Looks like the current estimates ship date is 5/18/16.
Anyone running the Pro tires now have any feedback on them? Tire pressure suggestions, etc?
Old 04-23-2015, 07:45 AM   #12
bhillakaiceberg
bhillakaiceberg's Avatar
Drives: 2011 2SS/RS & 2017 1SS
Still waiting for my order to show up at the house. Been a month since I ordered them.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE
Built/Tuned by Me
2017 Chevrolet Camaro 1SS Auto
9.29 @144.57mph ALL MOTOR SBE
#TEAMGPI Gwatney Performance Innovation
bhillakaiceberg is offline   Reply With Quote
Old 04-25-2015, 03:14 AM   #13
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Kinda expensive..299$ new stuff!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-25-2015, 11:00 AM   #14
Rdunn
Really, Really Fast
Rdunn's Avatar
Look great. Just wish they were 28" tall. They are only 27.7 I believe.
For now I will be sticking with the MH325 since it measures at 28" tall
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
