03-19-2016, 12:16 PM | #1 |
Drives: 2011 ls camaro Join Date: Dec 2014
nitrous bottle pressure sensor connection.
okay so i have the glowshift nitrous pressure gauge and the sensor connects to where you would put a gauge in the bottle. just picked up the nytrex bottle heater and its controlled by pressure at 900 it turns off and it turns back on anything under that pretty cool set up. my issue is the sensor goes the exact same place......is there a T or somthing that i could put in the line so that i can connect one of the two sensors there if so witch one should i put there
03-20-2016, 11:17 AM | #2 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
I"m getting ready to install one myself. I'm going to use the gauge adapter fitting where the nitrous line meets the solenoid. Than I won't need 12' of wiring either.
03-20-2016, 11:19 AM | #3 |
