06-08-2012, 11:06 PM | #1 |
Drives: 11 SS/RS Vert/E-ForceSupercharger Join Date: Aug 2011
Anvil spoiler on vert?
Is the vert trunk deck the same as the coupe?
Will it cover the existing SS spoiler marks on the trunk lid? Is it simple to install the AM / FM antenna into the Anvil spoiler? I'm trying to install spoiler on a 2011 vert and Anvil is not sure it will work? Anyone have this setup? I'm trying to keep the top breaklight so I like the lowered center. thanks. |
06-09-2012, 12:00 AM | #2 |
HT5 COTW 9/3/2012
Yes it would Fit and look perfect.
06-09-2012, 10:19 AM | #3 |
Drives: Black 2011 Camaro LS Join Date: Feb 2011
You'd be the first vert I've seen with one.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob SS Fascia, Factory RS HIDs, Plasma P13W fog lights Non-RS to RS and fog light harness by Gen5DIY LED Interior, Trunk, and Licence Plate lights in white ZL1 Spoiler with Gen5DIY harness Factory NPP cat back Blacked out tail light bezels Factory 20 inch wheels wrapped in Nitto Motivos Lowered 1.25inch on Eibach Pro springs |
06-09-2012, 10:31 PM | #4 |
That's my fear - to be the first. Don't mind leading the way, but the
manufacturer can't even give an answer? I have seen a few verts on this site with the GM dove-tail spoiler, but you should omit the factory brake light as it will be blocked. |
01-01-2015, 10:00 AM | #5 |
2013 Victory Red LS3 Vert
Drives: 2013 SS/RS Join Date: Jul 2013
You ever get a answer on this? I want to add this spoiler to my vert
01-02-2015, 03:11 PM | #6 |
Drives: 2013 Black Camaro 2SS/RS Convert. Join Date: Jun 2013
2013 Camaro 2SS/RS-Smoked tail lights and side markers, HID log lights, & LED lighting inside/outside the car, SJM LED Cupholder, SJM full dashboard ABL lighting, ZL1 Rockers, 1LE Splitter, Showstopper LED Mirrors, Showstopper LED Side Markers, & Showstopper Heat Extractor Hood, 20" Niche Concourse ZL1 Styled wheels 20X8.5 & 20X10 with 275/40/20 & 315/35/20 Nitto Invos, Black Gorilla Lug Nuts/Locks, Black Billet Elite Camaro License Plate Holder, and Hydro Dipped Speedo/Shifter/AC-Heat Bezels.
01-02-2015, 03:45 PM | #7 |
Drives: 2013 Camaro 2SS RS Convt. Join Date: Mar 2011
I have a rear spoiler from MPD1. It is set up for the am-fm antenna. The antenna is still in my stock spoiler, so I'm still with out am-fm. I have heard of some people removing the stock antenna from their spoiler and placing it underneath the rear bumper cover. I know of one other guy on this forum that has the same spoiler as me. I'm not sure what he did with his antenna though. I did a search and found found this. Maybe it will help someone here. http://www.slponline.com/instructions/100041C.pdf
Here's my rear spoiler:
2013 Nickey Stage II Camaro SS Convertible #10.Black w/ Red leather interior. No Weeds Elec. Diverters, CNC ported heads, custom grind cam, upgraded fuel injectors, ZL-1 fuel pump, V-Max ported TB, Red Magnuson Super Charger with rear cog drive, upgraded rear axles good for 1400Hp, 3:45 gears, Tremec 6 spd., Pedders adj. coil overs, Phadt ZL-spec swaybars, 800Hp at the crank, 670RWHP, 613ft.lbs. torq. @ 11lbs. boost. SOLD!!!
03-22-2015, 03:33 PM | #8 |
Did anyone ever install this on a vert?
01-26-2023, 06:00 PM | #9 |
01-27-2023, 09:21 AM | #10 | |
https://www.camaro5.com/forums/showthread.php?t=49366
