12-21-2011, 06:03 PM | #1 |
OFF THE CHAIN
Magnuson Supercharger & Boost Gauge?
I know where to connect the boost gauge but all the Magnuson has is a nipple for a hose. Do you just connect a hose to that and run it over near master brake booster, then connect the hose to my sensor? I am using an AEM Boost gauge!
12-21-2011, 06:12 PM | #2 |
Yes, the Maggie has a port on the back of the lower intake that is there for boost reference. You can route the hose to your gauge. There is a hole in firewall from the factory with a grommet. It is near the Master Cylinder and makes a great pass-thru for accessories. I use it for gauges and methanol all the time.
12-21-2011, 06:14 PM | #3 |
OFF THE CHAIN
You got a photo of the hole in the firewall? Also thanks a lot i appreciate it!
12-21-2011, 06:14 PM | #4 |
OFF THE CHAIN
Also where did you get ac power from?
12-21-2011, 06:23 PM | #5 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
The hole in the firewall is way up high above the dead pedal on the driver's side.
12-21-2011, 07:45 PM | #6 |
OFF THE CHAIN
Another question, why when i hooked up boost gauge it says -20 psi?
12-21-2011, 07:55 PM | #7 |
12-21-2011, 07:59 PM | #8 |
OFF THE CHAIN
Terri you rock, i had a supercharger before but never had any gauges
12-21-2011, 08:00 PM | #9 |
OFF THE CHAIN
Oh by the way Terri you can come to my build thread to give me some advice?
12-21-2011, 08:52 PM | #10 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
what fuse do you tap into?
12-22-2011, 12:00 AM | #11 |
OFF THE CHAIN
Actually i will be tapping into ac power in the harness on drivers side!
12-22-2011, 12:31 AM | #12 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
search as "firewall pass through" that's how I found it...driver's side firewall about 4" above power cable you will see a hole with a grommet a little smaller than your thumb. Easy to poke out. From inside the car, it is above the kick panel trim a couple of inches toward the side.
-John S.
12-22-2011, 09:03 AM | #13 |
anyone have a pic of where the line plugs into the maggie?
12-22-2011, 10:15 AM | #14 |
I get power from the back of the fuse box on the drivers side. I tap into the green wires that are for the 12V accessory ports. I don't like to have wires going in on the front side. This makes a real clean set up. When you remove the fuse box cover it still looks factory. All the wires are hidden behind the fuse box.
I also added a separate fuse holder. The grommet is behind the firewall insulation. You can just poke a hole in it and pass your hose or wires through it. |
Similar Threads | ||||
Lethal Racing Supercharger Install Specials | Lethal Racing | Local Marketplace | 28 | 12-27-2011 08:11 PM |
Vortech vs Maggie | IPAINTBRIDGES31 | Forced Induction - V8 | 34 | 03-27-2010 05:48 PM |
STS Twin Turbos | SupremacyCustoms | Forced Induction - V8 | 0 | 02-16-2010 01:35 PM |
Boost Gauge | ZZcamaro | Cosmetics and Lighting Modification Discussions | 10 | 10-18-2008 07:34 AM |
