02-19-2020, 11:30 PM | #1 |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Dec 2019
Help me solve this issue
Hi everyone, this is what is going on with my car
2014 2ss rs 1le arh longtubes no cats corsa sports k&n cai tuned it does have 2 12" subs (previous owner) (i think this might play into my issue) Here is what is going on, i get codes for P0351 P0355 P0357 ive swapped the coils to see if the codes will follow, they do not ive put all new plugs, wires, wire heat shields, etc ive checked the grounds, they are all tight, the car will sometimes start up and it will pop/back fire very loudly, other times it starts up just normally. Sometimes I will just be accelerating and it will shutter and shake roughly. Sometimes i will just keep going and the problem will disappear, im pretty sure that this is an electrical issue because it does not happen all of the time, whereas a mechanical one would be more prevalent. does anyone on here have any suggestions? |
02-19-2020, 11:39 PM | #2 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Tuned by whom?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
02-19-2020, 11:42 PM | #3 |
02-20-2020, 02:29 PM | #4 |
Psycho on day pass
Drives: 2010 yellow 1ss m6 -GM tech Join Date: Apr 2009
Looks like the drivers side coils #1, #5 and #7 are not firing properly.
Maybe a pinched wiring harness or PCM fault. Open the harness on the drivers side from each coil and trace it back to the computer as far as possible looking for break in the harness or pinch. Check connectors at PCM for pin drag or corrosion. If harness check is good, I would suspect a PCM issue. Circuit/System Description The ignition system on this engine uses an individual coil for each cylinder. The engine control module (ECM) controls the spark event for each cylinder through the 8 individual ignition control circuits. When the ECM commands the ignition control circuit ON, electrical current will flow through the primary winding of the ignition coil, creating a magnetic field. When a spark event is requested, the ECM will command the ignition control circuit OFF, interrupting current flow through the primary winding. The magnetic field created by the primary winding will collapse across the secondary coil windings, producing a high voltage across the spark plug electrodes. The ECM uses information from the crankshaft position sensor, and the camshaft position sensor for sequencing and timing of the spark events. The ECM monitors each ignition control circuit for improper voltage levels. Conditions for Running the DTC The engine is running. Ignition voltage is greater than 5 V. The DTCs run continuously when the above conditions are met. Conditions for Setting the DTC The engine control module detects that the voltage command state of the driver and the actual state of the control circuit do not match. Action Taken When the DTC Sets DTCs P0351, P0352, P0353, P0354, P0355, P0356, P0357, and P0358 are Type B DTCs. Conditions for Clearing the MIL/DTC DTCs P0351, P0352, P0353, P0354, P0355, P0356, P0357, and P0358 are Type B DTCs. Engine Running. Verify the scan tool parameters listed below do not display Malfunction: Ignition Coil 1–8 Control Circuit High Voltage Test Status Ignition Coil 1–8 Control Circuit Low Voltage Test Status Ignition Coil 1–8 Control Circuit Open Test Status If Malfunction is displayed Refer to Circuit/System Testing. If Malfunction is not displayed Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data. Verify the DTC does not set. If the DTC sets Refer to Circuit/System Testing. If the DTC does not set All OK. Circuit/System Testing Ignition OFF, disconnect the harness connector at the appropriate T8 Ignition Coil. Engine Running. Verify the appropriate scan tool Ignition Coil Control Circuit Low Voltage Test Status does not display Malfunction. If Malfunction is displayed 3.1. Ignition OFF, disconnect the X2 harness connector at the K20 Engine Control Module. 3.2. Test for infinite resistance between the control circuit and ground. If less than infinite resistance, repair the short to ground on the control circuit. If infinite resistance, replace the K20 Engine Control Module. If Malfunction is not displayed Verify the appropriate scan tool Ignition Coil Control Circuit High Voltage Test Status does not display Malfunction. If Malfunction is displayed 4.1. Ignition OFF, disconnect the X2 harness connector at the K20 Engine Control Module. 4.2. Test for less than 1 V between the control circuit and ground. If 1 V or greater, repair the short to voltage in the circuit. If less than 1 V, replace the K20 Engine Control Module. If Malfunction is not displayed Ignition OFF, install a 3 A fused jumper wire between the control circuit terminal C and ground, engine Running. Verify the appropriate scan tool Ignition Coil Control Circuit Low Voltage Test Status displays Malfunction. If Malfunction is not displayed 6.1. Ignition OFF, remove the fused jumper, and disconnect the X2 harness connector at the K20 Engine Control Module. 6.2. Test for less than 2 Ω in the control circuit end to end. If 2 Ω or greater, repair the open/high resistance in the circuit. If less than 2 Ω, replace the K20 Engine Control Module. If Malfunction is displayed Test or replace the T8 Ignition Coil. Component Test Note: You must perform the Circuit/System Testing before proceeding with Component Testing. Ignition OFF, connect the EL 26792HEI Spark Tester to the appropriate T8 Ignition Coil. Engine Running. Verify the spark output of the T8 Ignition Coil. If no output or the output is weak Replace the T8 Ignition Coil. If the output is normal All OK. |
02-20-2020, 03:17 PM | #5 | |
You’re a beast. Thank you very much Sent from my iPhone using Tapatalk |
02-21-2020, 02:03 PM | #6 |
Psycho on day pass
Let us know what you find!!
02-21-2020, 03:27 PM | #7 |
03-03-2020, 02:28 PM | #8 |
Dealership now says I have a bad ecm on a 50k mile car. What are everyone’s thoughts?
03-06-2020, 07:12 PM | #9 | |
They wiped my ecm and my tune, so I have to get it retune. car has LTH no cats and a CAI. I figured the check engine light was on because of no cats. I went to the auto parts store down the street and I pulled the same Engine Coil Codes. Dealer said they fixed it. Its not fixed. Im extremely frustrated at this point |
03-06-2020, 07:43 PM | #10 | |
09-04-2023, 03:33 AM | #11 |
Drives: Chevrolet Camaro Join Date: Aug 2020
Old thread but what ended up being your issue, I’m having the same problem.
09-04-2023, 07:56 PM | #12 |
Drives: 15SS Camaro Join Date: Dec 2020
If it was mine and you covered the normal things I'd be check cold and hot compression for cracked broken rings-ring lands and looking at the wave forms concerning the crank sensor. Another thing to consider is can you feel it missing or are you just getting the codes.
09-04-2023, 08:09 PM | #13 |
09-06-2023, 04:43 PM | #14 |
I had a issue where I, a seasoned wrench, could not fix. Whipple Blown with a cam. Ran rough and very difficult to start. After blowing $$$ on parts like a new TB, Pedal, cleaning grounds, etc, got serious and engaged Pro Tuner Mr Ted Jannety. His approach is meticulious, analytical, knows what parts to update/change, and his tunes are based on proven applications and DL analysis. You will follow a strict regemine. Prepare for data logging and interaction until problem solved. My car is not only fixed, but is a amazing transformation, and worth every $$ spent on his tune and analysis.
