07-06-2013, 02:35 PM | #1 |
Drives: 2011 RJT Camaro LT2 RS auto shift Join Date: Dec 2011
Sirius satilite antenna dirt ring on roof.
I went with a Kenwood Gps navigation radio. Ii required a different Sirius radio tuner then the one I had. The new antenna works better then the old one so I switched them. Now there is a ring where the antenna and wire was. Soap and water will not remove it.
What could I use to remove or make it better then it is now?
Caddy
07-06-2013, 03:04 PM | #2 |
I like teeth.
Drives: #198 Join Date: Oct 2009
clay, and then polish if that doesn't work. Do you have a machine?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517 "When you want to succeed as bad as you want to breathe, then you will be successful." |
07-06-2013, 03:31 PM | #3 |
No machine . I take it in and have washed and waxed. I'll get some clay bar and try it. Woud you what would be decent bar from autozone.
Caddy
07-06-2013, 03:38 PM | #4 | |
I like teeth.
For the same amount of money however, you can get the nanoskin sponge set online. You can clay your car many more times and it is much better all around. I would recommend that over anything you'll buy in stores.
07-06-2013, 03:39 PM | #5 | |
I like teeth.
07-06-2013, 03:58 PM | #6 | |
Caddy
Thread Tools | |
