08-31-2013, 03:15 PM | #1 |
Romanian Outlaw
Drives: 13 ZL1 , 14 Silverado Crew Cab Join Date: Apr 2010
Roto-fab reservoir tank sucks
So every bodies been having problems with the cap.... Well my issue today was a bolts to short that hold the tank in place,had to go buy another one. So a job that would've taken 20 min took an hour and a half. Roto-fab is slacking off wth guys!!??
[/SIGPIC]2013 Camaro ZL1 M6
08-31-2013, 03:36 PM | #2 |
Drives: 18 ZL1 A10 & 18 2500HD Duramax Join Date: Oct 2012
Procharged 2018 ZL1 A10
2018 2500HD Duramax |
08-31-2013, 03:43 PM | #3 |
Romanian Outlaw
I got the Katech h/x and I ordered the roto from LPE.. I'll post up pics in a new tread with the h/x
08-31-2013, 03:56 PM | #4 |
Plastic coolant tank just doesn't make sense to me. That's why I like D3PE reservoir tank, it's made out of aluminum. I heard good things about the katech exchanger, but not for the roto-fab tank.
08-31-2013, 04:11 PM | #5 |
Romanian Outlaw
Yeah I'm already regretting the roto-fab tho.. I know the ctsv guys use these h/x so we'll see..
09-02-2013, 11:56 AM | #6 |
Romanian Outlaw
Wow Roto-fab really has dropped the ball on these tanks now the dang cap won't tighten wth?? Now I have to wait till tm to even get ahold of these guys!! So much for driving my car today!!!
09-02-2013, 12:55 PM | #7 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
I'm gonna chime in and say the Roto-fab res sucks. I did a write up a while ago when I got my res but mine came with cap fitment issues. Long story short, Roto-fab sent me another tank and the cap fit great with no leaking issues. Well, that was then and this is now. The cap is leaking again and I have lost my patience with this product. Roto-fab makes the reservoir and LPE sells it. I don't know who to blame but I've given up on the tank. I ordered a D3 tank which should be here soon.
09-02-2013, 01:19 PM | #8 |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
I liked the location of the roto fab tank but like everyone else over time my cap has started to leak!!!! I ended up getting an extra tank when I ordered my CAI last year so I've dropped my extra tank off at a fab shop and I'm getting the identical tank built out of aluminum, that way they can machine the top of the spout( mine appears to leak right where the last plastic thread leaves off ) also I've asked the shop to move the return inlet from the back of the tank to the engine side to shorten that long hose you have to route around the back of the tank. Not happy either, add me to the list
09-02-2013, 02:12 PM | #9 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
So my question is: Why is roto fab not doing anything about this?
09-02-2013, 02:26 PM | #10 |
Drives: 2012 CAMARO ZL1, 2012 CTS-V, Join Date: May 2012
My Roto FAb working good . Got cap at auto zone did not come with cap! $5.00 . Quick install .
09-02-2013, 02:41 PM | #11 | |
Drives: 2011 2SS Convertible Supercharged Join Date: Nov 2010
I would think that aluminum tank will absorb more under hood heat than a plastic tank. Someone take temps of both after a hour drive and report back. |
09-02-2013, 02:47 PM | #12 | |
Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
One thing to consider the plastic provides a little insulation from under hood heat. Aluminum is great for heat transfer but provides no insulation value under hood. That aluminum will be hot! The custom aluminum reservoirs we made for Super Chiller cars were insulated the same as the Chiller. |
09-02-2013, 02:57 PM | #13 | |
Right on. I am a certified welder. I know about heat transfer. |
09-02-2013, 03:08 PM | #14 |
iRacing Pro
Drives: 2019 Camaro ZL1 1LE Join Date: May 2009
Mine too is leaking since the begining.Tried to order another one but BackOrdered cause of the problems of the res .To fix the problem till they fix the dam leaking problem.I put Teflon Tape around the threads.So far so good.Good luck guys!
