Old 07-24-2013, 09:09 PM   #1
epkmvuoq
Drives: 2ss red m6
Engine temperature
What does your ls3 run in stop and go traffic,,, interstate ,,,and normal. Thanks.
epkmvuoq is offline   Reply With Quote
Old 07-25-2013, 08:56 AM   #2
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
After a fair amount of time warming up, my LS3 runs about 193 on the highway and gets up to 195-205 around town. On the road course it got up to 215. At the drags stock it varied between 170 and 205 which significantly affected my times.
Cuda7050 is offline   Reply With Quote
Old 07-25-2013, 12:37 PM   #3
epkmvuoq
Drives: 2ss red m6
Do you have to tune to make fans come on earlier ?
Old 07-25-2013, 01:20 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Yes, you could use a manual switch.
My fans are tuned to come on early.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-25-2013, 10:06 PM   #5
epkmvuoq
Drives: 2ss red m6
Thanks so much. I'll have to tune my fans. Not sure if true or not I've been told tuning a ls3 does NOT make a big difference in performance
Is this true ?
Old 07-26-2013, 08:20 AM   #6
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
Originally Posted by HRD_WRK View Post
If your racing-I'd recommend turning your fans on earlier/lower. Waiting till 220 is crazy.
My temps run for the most part whatever I want (within Normal scenario)- typically 180-190.
When stock-190-210
Tim
Yea, about a month ago I installed a 160 thermostat. It now cruises around at 180. I then added the manual fan switch. I can now come off the line at the drags consistently at 170. I will get back to the road course this fall and I doubt it will go over 200 unless I let it.
I live in the mountains where it snows, so time will tell if I need to get the stock thermostat back in there to get a usable heater.
Old 07-26-2013, 08:41 AM   #7
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
198* F max. It ran this way stock (190*-198*), and it runs exactly the same with the fans tuned to come on earlier.
Bye bye, Bumblebee!
Old 07-27-2013, 11:16 AM   #8
GQ4Life
Drives: 2010 Camaro SS LS3
at drag track in 90degree beating sun.. waiting in staging lanes ive seen it hit 210 then come back down..
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
