04-27-2014, 06:42 PM | #1 |
Question for IPF s/c owners.
My supercharger will hopefully be arriving in the coming weeks according to IPF. I've done a little bit of research leading up to this install and aside from the draining of the catch can every so often, what other types(if any) of periodical maintenance should I expect after installation?
"....Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
-Bruce Lee |
04-27-2014, 07:42 PM | #2 |
Drives: '14 1LS Join Date: Apr 2014
I personally dont have a ipf supercharger but i'd think changing your sc oil every so often and keeping an eye on the condition of your belt would be a good idea
04-27-2014, 07:53 PM | #3 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
The oil in the Vortech will need to be changed after the first 2,500 miles, then every 7,500 miles. I change mine every 5,000 miles with the engine oil.
Check the belt for excessive wear. |
04-27-2014, 09:13 PM | #4 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
belt at 20k for maintenance, SC oil at every oil change to be safe, keep a spare belt and tools to change, just in case. Ever try to find a long belt when you need one... good luck.
Also get a sock for the SC filter, helps in the rain, above all....HAVE FUN ....
04-28-2014, 01:49 PM | #5 |
Thanks for all the tips and suggestions. I know I can always count on the camaro5 faithful to help out... I will definitely keep and eye on that belt, and I'm already planning on keeping the tools and spare belt in a bag in the trunk, never know what to expect when you're cruising around.
So true. Haha
-Bruce Lee |
04-29-2014, 05:51 PM | #6 |
Make friends with your tire guy.
04-29-2014, 07:07 PM | #7 |
oh most definitely lol. I'll start talking to our tire guy at work.
-Bruce Lee |
