01-05-2012, 02:08 PM | #1 |
oil question
last time i got an oil change my machanic put in a 7500 mile synthetic blend oil. He said its good for 7500 miles and when im there ill get my tires rotated and get everything done at once. I just brought the car there put about 5000 miles since my last oil change and my oil life was at 20%. i decided to go back to the regular oil change
do you think the 7500 synthetic blend is good? or stick with regular oil? |
01-05-2012, 02:11 PM | #2 |
oh and he said if i put mobli 1 full synthetic i can go 10000 miles between oil changes but to check it at 5000 to see if i burned any oil and add if needed
just looking for opinions |
01-05-2012, 02:15 PM | #3 |
Drives: flintstone mobile Join Date: Dec 2011
synthetic oil is good.... not sure about a blend, I run Joe Gibbs hot rod oil
01-05-2012, 03:31 PM | #4 |
Drives: 10 2SS/RS Black, 99 Daktota Join Date: Apr 2010
The LFX engines are fine with a an approved dex blend, however, theres no harm in using full synthetic and lots of people recommend it over the blend to prevent additional wear and tear. Honestly though, you NEED to check your oil at-least every other fill-up. I do this religiously on my SS and all my cars, have never needed to add oil between changes on the SS, but still, i would rather know ASAP that the oil was being consumed so i could take it in to a shop and also to be able to keep it topped off. Waiting until 5k miles to check the oil just seems waaay too risky for me. Just my $.02
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
01-05-2012, 03:32 PM | #5 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
13,504 miles on our 2SS the last oil change using Mobil 1. I did change the oil filter at 50% with the needed make up oil of approx .5 qt. I got my oil analysis back and the oil still had life left. I will be posting my results soon with a narrative.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
01-05-2012, 03:47 PM | #6 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
The high mileage oil is good as long as it doesn't take 3 years between oil changes.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
01-05-2012, 04:12 PM | #7 | |
should i trust my oil life % or go by the miles? i check my oil to make sure im not short just want to know if its safe to go 7500 miles between oil changes? oh an i have the LLT Last edited by 2010camarolt; 01-05-2012 at 04:14 PM. Reason: added text |
01-05-2012, 04:13 PM | #8 |
mines my daily drivers it would only be 4 or 5 months deff not a year or years
01-05-2012, 04:32 PM | #9 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
I'll just add my take as I tear these down and build them often. NO oil except full synthetic!!! Blend is not good enough contional the motor will not last. The design of the dual overhead cam timing chains & VVT require the best syn period, no matter what GM or your dealer tell you.
01-05-2012, 05:19 PM | #10 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
FWIW, I'm changing over to Amsoil. Have a club member that's a distributor so get a little break on the price.
01-05-2012, 05:50 PM | #11 |
Drives: 4 wheels Join Date: Oct 2011
I'd recommend staying away from blends, why cheap out on your multithousand investment for a few bucks an oil change.
Listen to the people that open these engines for overhauls and performance builds, like the shop above SC2150 he has good insight that most don't. |
01-05-2012, 07:02 PM | #12 |
thank you all! what are some good full synthetic oils besides mobil 1? would just like some options for next oil change
01-05-2012, 09:08 PM | #13 |
Similar Threads | ||||
First oil change? | Fogey | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 27 | 09-18-2010 06:50 AM |
Oil Changes | Dave McFly | Off-topic Discussions | 6 | 05-18-2010 04:50 PM |
gas prices. | Congoman775 | General Automotive + Other Cars Discussion | 65 | 05-28-2008 12:20 PM |
