06-23-2014, 09:25 PM | #1 |
Drives: 2SS Transformer Eddition 2012 Join Date: Jun 2013
help me. please
I'm looking for new suspension. I want to stop the wheel hop and get more traction when going around the track. Im not to worried about money. I Just have no idea what to buy or even how much suspension upgrade cost. Please someone give me some advice. Pictures of upgrades would be great as well. I do plan to supercharge in the future
06-23-2014, 10:28 PM | #2 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
What type of track (drag vs auto-x)?
Daily driver? What wheels and tires do you have? What power levels are you looking to reach? Do you currently have any other mods? Here's a link to some suspension setups with everything you might want to replace highlighted in red: https://www.wretched.co/tech-talk-main/tech-talk-camaro
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
06-24-2014, 12:14 AM | #3 |
Drives: '69 SS Convertible Join Date: May 2009
One of the best things you can do is Trailing Arms. Good thing is there cheap, easy to install, and don't require an alignment. After that look at getting some cradle bushings. You'll be surprised at how much those two alone will help.
If you want someone to call and talk to give www.jdpmotorsports.com a call.
Build Journal |
06-24-2014, 10:36 AM | #4 |
Drives: Race Car Join Date: Sep 2009
Caverman gave some good advice. To resolve wheel hop issues, most folks start with a good set of Trailing Arms and the Outer Bushings. Other components that can contribute to wheel hop are the Cradle Bushings, Rear Upper Control Arm Bushings, and Toe Rods. Of course, all these components don't necessarily need to be changed all at once, but depending on your budget and the amount of time you want to spend under your car, it is certainly more convenient to do it all at the same time. And if you're looking for improved track performance (I'm assuming auto-x or road course), I would highly recommend upgrading the sway bars, which are the biggest "bang-for-your-buck" suspension upgrade. Here's a list of the recommended BMR Components (prices can be found on our website).....
TCA026 -- Trailing Arms BK006 -- Outer Trailing Arm Bushings BK024 -- Pro Version Cradle Bushings BK039 -- Rear Upper Control Arm Bushings TR002 or TR003 -- Toe Rods SB037 -- Sway Bar Package |
06-30-2014, 08:30 PM | #5 |
Bmr if I buy what you recommend when I supercharge will I need to upgrade again. I only want to buy once and have the best. Is everything above somthing I could do myself or do you need to bring to a garage
06-30-2014, 08:35 PM | #6 |
Daily driver about 650 700 hp. I have kooks long tube headers with high flow cats and american thunder 409 flowmaster and look for less wheel hop and to hug the corner better
06-30-2014, 08:45 PM | #7 |
http://www.bmrsuspension.com/?page=p...855&superpro=0. Is this the best package its stage 3 handling package from bmr
07-01-2014, 10:19 AM | #8 | ||
Thread Tools | |
