07-25-2013, 09:51 AM | #1 |
voodoo
Drives: 2010 Camaro Black 2LT RS Join Date: Jan 2010
Ported Throttle Body & Error Codes
I recently installed a VMAX Ported Throttle Body and a VMAX Black Ice-olator. After installation I got the following error codes. After driving about 30 mixed condition miles. The codes were gone (reset). Is this normal?
Code PO122 Throttle/Pedal Position Sensor A – Circuit Low Input Code PO223 Throttle/Pedal Position Sensor B - Circuit High Input.
Black 2LT/RS Auto
Modifications: K&N Cold Air Intake (performance), Corsa Cat Back Exhaust (performance), VMAX Ported Throttle Body (performance), VMAX Black Ice-olator (performance), Elite Catch Can (long term performance), Blacked out Chevy Bowties and Badges (cosmetic), Oracle Concept LED side markers (cosmetic), Oracle Concept side mirrors with LEDs (cosmetic), Technostalgia LED Tail lights (cosmetic), Foose Legend wheels (cosmetic), 35% window tint (cosmetic), dirty (cosmetic) |
07-25-2013, 10:33 AM | #2 |
voodoo
Computer Learn
I understand the computer had to "learn" the new intake. But I was wondering if this was expected.
Black 2LT/RS Auto
07-25-2013, 10:43 AM | #3 |
Drives: 2010 ABM 2LTRS, E46 330XI Join Date: Jun 2011
Yes although some have not had that issue. I had the same issue and just cleared the codes since then I've drove 1000 miles with no code or negative affect
07-25-2013, 11:14 AM | #5 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Was the install done with the battery connected ? Typically you should disconnect the battery according to the GM manual when removing the throttle body or for that matter any electrically connected component.
Just reset the codes, it should be fine.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
07-25-2013, 11:26 AM | #6 |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
+1.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
07-25-2013, 12:12 PM | #7 |
That is true disconnect the battery that may have been my problem as well
07-25-2013, 12:26 PM | #8 |
voodoo
Thank You
Thanks for the comments everyone. BTW this mod is great. I can really feel a performance difference.
Black 2LT/RS Auto
07-25-2013, 03:50 PM | #9 |
Drives: Camaro Join Date: Feb 2011
i got these error codes too. I took the tb out cleaned it, and unplugged the negative cable and plugged it back in several times for it to clear. It was good for about a week and a half. then i went on vacation for 4 days and came back to find the CEL on again.
I then did some more research and found another c5 member unplugging the + cable for the error code and leaving it over night did the trick. I did + and - cable for about an hr.. its been about 3 weeks 400+ miles and it has not came on back yet. |
07-25-2013, 04:59 PM | #10 | |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
The throttle body is just resetting its position. |
