08-12-2013, 07:01 PM | #1 |
P0449? What's the cause/fix?
So I got CEL the other morning on my way home from work, took it to AutoZone and I've got a P0449 code - Evaporative Emission Control System Vent Valve/Solenoid Circuit
Anybody know what a likely cause is? Also how severe? I can't make it to the dealer until Friday at the earliest, but if its a simple problem, easily remedied, then I won't bother with the trip at all. Thanks in advance!
08-12-2013, 08:15 PM | #2 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Sound like gas cap issue ? Have you checked the cap to make sure it's on ?
It should reset itself after awhile.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
08-12-2013, 08:26 PM | #3 |
Drives: 2SS/RS Join Date: Sep 2008
It's 1 of 3 things.
1) Loose gas cap 2) Evap. Emission canister. I haven't looked on the Camaro but I've had this issue on a couple other cars and was able to replace it myself. 3) Evap. Emission solenoid. This is located inside the gas tank and requires the gas tank to be removed. The most likely cause is the 1st one, with the next likely being the 2nd one. Solenoids do go bad but it's rare. |
08-12-2013, 08:35 PM | #4 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Evap Purge Sol is mounted on the front pass side of the LS3 as I recall from relocating it for my SC. Never heard of one in the tank but I'm old & a feeb.
08-13-2013, 04:50 AM | #5 | |
Evap. Purge and Evap. Emission is two different things. This is like the op asking about the fuel filter and you coming on and giving him info on the oil filter. |
08-13-2013, 05:37 AM | #6 |
So I did check the gas cap before leaving for work today... light is still in. Is there a way to clear the light manually? Remove negative battery cable maybe and see if it goes away?
Is this something the powertrain warranty covers? I'm well past the bumper to bumper, but still within the powertrain coverage? We're talking about emission stuff, so I imagine this is semi-important but not terrible if I drive the car all week correct? I have to drive to work until Thursday... After some Google searches,the best results coming right from Camaro5 of course, this looks like a common GM problem, not necessarily warrantied. Well shoot... if it is just the canister, does anybody have any experience replacing it? From what I read canister is cheap, solenoid quite the opposite.
08-13-2013, 06:52 AM | #7 |
Drives: 2012 Camaro 2LT RS Join Date: Mar 2012
08-13-2013, 06:54 AM | #8 |
Diagnostic Fault Information
Circuit Short to Ground High Resistance Open Short to Voltage Signal Performance Ignition 1 Voltage – Purge Supply P0443 P0443 P0443 — — Battery Positive – Vent Supply P0449 P0449 P0449 — — Evaporative Emission Purge Solenoid Valve Control P0443 P0443 P0443 — — Evaporative Emission Vent Solenoid Valve Control P0449 P0449 P0449 P0449 — Circuit/System Description An ignition voltage is supplied directly to the evaporative emission (EVAP) canister purge solenoid valve. The engine control module (ECM) grounds the evaporative emission canister purge solenoid valve control circuit through an internal switch called a driver. The ECM monitors the status of the driver. The evaporative emission canister purge solenoid valve is pulse width modulated (PWM). A scan tool will display the amount of ON time as a percentage. Battery voltage is supplied to the evaporative emission canister vent solenoid valve. The ECM grounds the evaporative emission canister vent solenoid valve control circuit through an internal switch called a driver. The ECM monitors the status of the driver. A scan tool will display the commanded state of the evaporative emission canister vent solenoid valve as ON or OFF. Conditions for Running the DTC
The ECM detects that the commanded state of the driver and the actual state of the control circuit do not match for a minimum of 5 s. Action Taken When the DTC Sets DTCs P0443 and P0449 are Type B DTCs. Conditions for Clearing the MIL/DTC DTCs P0443 and P0449 are Type B DTCs. Reference Information Schematic Reference |
08-13-2013, 07:40 PM | #9 | |
It is not related to the powertrain so most likely not. You'll be fine driving it this way. My dad's Impala had the same issue and he drove it for months before getting it fixed. You'll have trouble getting gas when you fill up but it won't effect driving in the least. I have not looked at the Camaro, but on other vehicles I've done it was really easy. If you have a set of ramps, you could probably do it yourself in 30 mins. |
08-14-2013, 05:33 AM | #10 |
Thanks, I appreciate the help! It's good to know it's not a major issue. I'll try disconnecting the battery tonight. If was just the gas cap it probably would've gone away on it's own right?
08-14-2013, 08:36 AM | #11 |
For the light to turn off on it's own, the ECU will have to run and pass the test that caused the light twice. Without a scan tool, it wil be hard to know if that has happened. Find a scan tool and reset the light or disconnect your battery. If you disconnect your battery though, you will most likely lose your radio presets and window indexing. Better to reset the light with a scan tool.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
08-15-2013, 09:34 PM | #12 |
Drives: 2010 camaro ss Join Date: Jun 2010
I have this same problem too. What are the chances that the gas cap went bad?
08-17-2013, 10:00 AM | #13 | |
Geek
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
09-03-2013, 09:01 PM | #14 |
Does anybody know where these sensors located on the car??
