Old 11-29-2017, 06:07 PM   #1
TrevinE
TrevinE's Avatar
Drives: 1967 Camaro RestoMod
SOLD
As much as I hate to do it, i am listing my fresh build for sale. Literally, I just got it back from the tuner after the Late Model Engine built 416 break-in. Maybe 30 miles on the new build. The build took longer that I expected and in the process, I wound up acquiring 2 jeeps that i started to rebuild so need the room. Below is a list of everything i can think of. If you need more details, I can get them. I also have more hi def pictures i can send. If needed, i can get a dyno run. The tuner's dyno was giving him erratic readings so all he could do was get the engine broken in and dial it in. From the LME engine to the 6L90 transmission conversion (yes, a 6L90), no expense was spared in this build. It is likely 900RWHP plus or minus on a Mustang dyno at 15 PSI. She's a real head turner and will flat our run. Feel free to call me with any questions. Asking $38,000 OBO Trevin 832.752.1202
LME Built 416 Motor
2.9 Whipple Supercharger w/2.875” Pulley
6L90 Transmission Upgrade
ID1050X Injectors
Nick Williams 102MM Throttle Body
Pegasus 10 Rib belt system
Triple Disc 3400 Stall
Custom Grind Cam
E85 Flex fuel
Fore Triple Pump Fuel system
ATI Balancer
Dual Nozzle Alky Control Meth Injection
TCI Line Lock
CAI Intake
ADM Transmission Cooler
RPM 6 Point roll cage (Bolt-In Removable Bases with Quick Connect for easy removal of roll bar)
BMR/Detroit Speed suspension upgrades
- Sway bars
- bushings
- tow links
- trailing arms
3.73 gears
L99 to LS3 DOD delete conversion
Kooks headers
Stainless Works 3 exhaust
Race Star 95 Recluse 18” wheels
Front: Pirelli PZero Rosso 255/55/18
Rear: Mickey Thompson 305/45/18
You Tube Video Links:
https://youtu.be/TXowRRwGgBg
https://youtu.be/sYn5XpUar9s
1967 Camaro Resto Mod. 468 roller. Tremec TKO600, 2011 Imperial Blue Metallic paint, full Hotchkis suspension, Wilwood disc brakes, Ron Davis radiator, Comp Cam, Custom aluminum air intake, custom valve covers, Rushforth rims, ET street radial IIs
TrevinE is offline   Reply With Quote
Old 12-03-2017, 09:03 AM   #2
TrevinE
TrevinE's Avatar
UPDATE: I have had some questions about the roll bar.
1) Yes it is a 6 point system. However, i only mounted the rear 4 points. They are bolt-in mounts.
2) Yes, the roll bar removes without having the effort of removing the mounts. There are 2 allen head bolts in each of the 4 rear points. Remove them and it pulls right out.
3) I did not install the front 2 but the mounts and door bars will convey with the sale.
I added some photos of the roll bar here upon request and added some of around the tires to show its clean and zero issues.
Thanks
Old 12-11-2017, 12:17 PM   #3
TrevinE
TrevinE's Avatar
Ready to get on with the other projects. IF you are at all interested, lets talk. Make me an offer. Worse I can say is no.
Old 02-06-2018, 03:11 PM   #4
TrevinE
TrevinE's Avatar
Spring will be here soon. Bring some offers.
Old 02-06-2018, 06:16 PM   #5
Bow Tie Affair
Drives: 6th. Gen ZL1
Your video links are not working.
Bow Tie Affair is offline   Reply With Quote
Old 02-07-2018, 08:09 AM   #6
TrevinE
TrevinE's Avatar
Both work for me via PC and mobile device. If you are interested, let me know and i will figure out a way to get them to you.
Thanks
Old 02-07-2018, 01:54 PM   #7
Tonka1
Drives: Camaro
Very nice car
Tonka1 is offline   Reply With Quote
Old 02-25-2018, 08:34 AM   #8
TrevinE
TrevinE's Avatar
Someone make me an offer. The other projects need to get done. Took advantage of the nice weather yesterday and got her out to stretch the legs. It is an awesome car. Fast yet reliable with great street manners.
Old 03-01-2018, 03:33 PM   #9
TrevinE
TrevinE's Avatar
Video Links should be working again. YouTube rookie. Someone let me know if they are or are not. Thanks
Old 03-28-2018, 07:43 AM   #10
TrevinE
TrevinE's Avatar
Spring is her. Drop the top and enjoy!
Old 04-03-2018, 10:58 PM   #11
leemozoid
leemozoid's Avatar
Drives: '15 Silverado LTZ & '13 ZL1 ragtop
Would you consider removing the roll cage and selling it separately? If so, how much?
leemozoid is offline   Reply With Quote
Old 04-04-2018, 11:50 AM   #12
TrevinE
TrevinE's Avatar
Sorry. Goes with the car.
Old 05-27-2018, 09:32 AM   #13
TrevinE
TrevinE's Avatar
Summer is here. Someone can enjoy this freshly built beast.
