04-03-2014, 03:38 PM | #1 |
Drives: Black aSS 2011 - L99 Join Date: Apr 2012
Tire Sensors and Rotation opinions needed....
Ok I will try to make this short. My "service tire pressure system" light went on and it doesn't read tire pressure anymore. I don't guess anyone knows how to disable it so the alarm and auto start works either. I have one of the late 2011's that needs the TPMS tool. So here is my question: I have read a few places that Camaro owners are now trying to get more tire tread life by rotating right to left cause you can't go front to back. The guys who put my tires on recomended if I rotate left to right they have to remove the tires and "flip them over" because the balance wont be right if they dont due to the fact they will be spinning the opposite direction. Does anyone agree with this and have you had it done? I dont want to open a can of worms where I get steering wheel vibration by not doing the right thing. AND does anyone know how to disable the tire pressure system so the remote features work? Thank you.
Staying stock and loving it............
04-03-2014, 03:41 PM | #2 |
Trust me I'm a Scientist.
There's steps to reactivate them yours is not broken you just need to reactivate them. By letting air out from each tire in a specific order
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator. |
04-03-2014, 04:04 PM | #3 |
That doesn't work for me, I have one of the late 2011's so it has to be the tool. Already tried that but thanks anyway.
04-03-2014, 04:42 PM | #4 |
MY SS is SOLD
Drives: AGM 2012 Camaro 2SS/RS L99 Join Date: Mar 2012
If your tires are directional then they would have to take them off the rims and remounted correctly so when you swap sides they will still be rotating the same/correct direction. My stock pzero's are not directional so I just do a side to side swap and they spin in the opposite direction. I have done this a few times per owners manual, I have about 24K on them and it looks like I might get 30K out of them(maybe). As far as the tpms I would take it to the dealer or back to the tire shop and have them reset the system. Hopefully that's all it needs.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
04-03-2014, 05:33 PM | #5 | |
Drives: 2018 ZL1 2015 1SS 1LE Join Date: May 2013
I have swapped my stocks with no issues. But someone please educate me as well if I am incorrect.
2018 ZL1 2015 1SS 1LE Stock...ish |
04-03-2014, 07:50 PM | #6 |
TPMS can not be disabled. Your either going to have to fix it or live without auto-start. I'd swing by a tire store and get them to try a reset first.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
04-04-2014, 11:49 AM | #7 | |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
On a side note if you buy a set of non directional tires and mount them on a stagger set up like the Camaro SS has, with some manufacturers the factory warranty won't cover them any longer as they can not be properly rotated.
USMC 1980-1990
My other toys are Harleys |
04-04-2014, 11:56 AM | #8 |
Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
You do not have an aftermarket stereo do you?
I have been having TPMS issues ever since installing my Scosche headunit. Apparently that can happen with the Scosche.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
04-04-2014, 12:57 PM | #9 | |
04-04-2014, 03:40 PM | #10 |
USMC 1980-1990
If they are the same size as far as the tire and wheel width yes you are correct. However I don't think I want to put the 8" front wheel in back and the 9" in front on my SS it might look funny..
USMC 1980-1990
04-04-2014, 04:04 PM | #11 |
Drives: A Gift From My Wife Join Date: Apr 2009
I had a similar situation like this happen this after noon. I finally scored another set of matching 275/40/25's so I can run them on all four corners.
At the tire shop I had them take the existing rear tires and move them to the front. They balanced the new set of rims I got and put them on the rear. After going about 10 miles the front TPMS quit displaying the tire pressure of the front tires and the "Service" message came up on the DIC. Any clues? Simple reset? -Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping. 08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery). 08/16/2011 - (5000) Vehicle has been delivered to dealer. 08/19/2011 - In my possession. |
04-06-2014, 03:22 PM | #12 |
Ok here is an update to my issue. And no I don't have an aftermarkrt stereo. I took it this weekend to the placethat mounted the tires and they came up with nothing. He tried the manual reset and also used the TMPS tool to do it and came up with nothing. He said the sensors were transmittig to the TPMS tool just fine. It was the car that wasnt picking up the signal. So I dont know......I even changed the tune back to stock and reset the trouble code it was throwing because of the TPMS. SO who knows, Im not going back to the dealer cause they will screw it up more probably.
04-06-2014, 06:13 PM | #13 |
Drives: 2011 2SS RS Join Date: Jun 2011
I also have a late 2011. The first year and a half I didn't have a single problem with the tire pressure system. But in the last year ive been to the dealer five times. They reset it and it will last a day or two. The car is out of warranty this month so I guess they win.
