Old 03-27-2016, 11:15 PM   #1
LSXDoc
LSXDoc's Avatar
Drives: 2015 1SS/RS/1LE
My 1LE got an upgrade this weekend!
I got a smokin' offer from Andy at ADM Performance, so I pulled the trigger on his Stage 1 kit with new GM LSA supercharger. I took it on in stages. First with the HX install, and then with the actual install. Took about 2 hours for the HX and another 8 or so for the supercharger. Tuning starts tomorrow.
Big shout out to Andy at ADM for the deal on parts and the several phone calls with questions (as this was my and the shops first LSA install). Also, another great thanks to Tim Gamble at Deep Stage Tuning in Norman, OK for the use of his shop and his help this weekend. I could not have finished this without both of their help.
2015 Red Hot 1SS/RS/1LE
ADM LSA kit
BTR Stg3 PD Cam
Stainless Power LTs w/ CATs
Stainless Works ZL1 Res. Delete 3" Retro Catback
DST Ported ZL1 TB
619RWHP / 539LB-FT
LSXDoc is offline   Reply With Quote
Old 03-27-2016, 11:29 PM   #2
CTSVBiggie
CTSVBiggie's Avatar
Drives: 2013 1LE
Much like. Must get. I need boost in my life
>>>>>>>>>>>MUST READ DISCLAIMER<<<<<<<<<<<<
2013 Crystal Red Tint Coat - 2SS RS 1LE
CTSVBiggie is offline   Reply With Quote
Old 03-28-2016, 08:12 AM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Sub'ed. Want to hear what numbers you get. Other than the LTH's (and HFC's I assume), any other engine mods going into this? Completely stock motor otherwise?
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 03-28-2016, 11:59 AM   #4
Camarotobeornottobe
Drives: 1LE
If you cared about such things, would the ZL1 engine cover fit on the LSA supercharged SS motor?
Camarotobeornottobe is offline   Reply With Quote
Old 03-28-2016, 02:36 PM   #5
Galaxy_Stranger
Drives: Black 2013 2SS LS3 1LE
Are you doing to have to modify anything else? Transmission?
What's this going to do to the power band?
Galaxy_Stranger is offline   Reply With Quote
Old 03-28-2016, 03:37 PM   #6
LSXDoc
LSXDoc's Avatar
From the looks of it, the supercharger has the mounting tabs for the cover. So I would think it will fit.
I will most likely need a clutch in the immediate future, and all the suspension upgrades to properly apply the power to the ground. As for the power band, not sure, this is the first LSA conversion I have worked with.
ADM LSA kit
BTR Stg3 PD Cam
DST Ported ZL1 TB
619RWHP / 539LB-FT
Old 03-29-2016, 12:06 AM   #7
1LE_LEO
Drives: 2014 Summit White 2SS/1LE
Looks good man, congrats. I'll be doing the same thing in a couple months can't wait. I'll be adding extra to my build. Anything difficult that you ran into?
1LE_LEO is offline   Reply With Quote
Old 03-29-2016, 06:05 AM   #8
supergt99
supergt99's Avatar
Drives: 2013 Camaro SS 1LE
congrats on the supercharger. yes the lsa cover fits
supergt99 is offline   Reply With Quote
Old 03-29-2016, 12:01 PM   #9
LSXDoc
LSXDoc's Avatar
You have to bend the steam tube like 30 degrees down and toward the driver side. It worried me a little but seems to be working. You have to either remove or trim the plastic pieces on each side for the HX. I chose to trim, preference I guess. You have to trim the heat extractor (14-15 only) because it will make contact with the top hose going to the LID. I spaced the heat extractor for now with washers because I don't want to cut on it. And lastly, the factory 1LE strut tower brace didn't clear, and I had to space it with washers as well. I will just buy a ZL1 strut tower brace and sell the one I have.
Outside of all of that, I got to drive it for the first time last night. Drove it to my tuner's house, and we did some street tuning. Let me say, OH MY GAWD! This car is a FREAKING BEAST! I had a friend tell me the 3.91s would be too much, but the car pulls so hard. The acceleration and power is ridiculous and instantaneous! I could not be happier.
ADM LSA kit
BTR Stg3 PD Cam
DST Ported ZL1 TB
619RWHP / 539LB-FT
Old 03-29-2016, 12:17 PM   #10
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
Do you track it OP? Wondering what the consequences of the SC are with heat on a track.
Thor142 is offline   Reply With Quote
Old 03-29-2016, 01:06 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Congrats.
I'm not sure why more SS peeps don't do this LSA conversion. .....
Mods:
Old 03-29-2016, 01:46 PM   #12
1LE_LEO
Thanks for sharing man.
Old 03-29-2016, 02:42 PM   #13
Thor142
Thor142's Avatar
Originally Posted by KaBoom1701 View Post
Congrats.
Well I can't speak for everyone but I'll be taking this car to the track several times a year and I would be VERY concerned with heat soak from the SC. Some people are putting additional oil coolers in the LS3 for track use because of high oil temps. Not to mention added weight in the nose.
Old 03-29-2016, 06:03 PM   #14
adam0311
adam0311's Avatar
Drives: 15' red hot 1le
Curious in numbers. Hopefully goin this route soon. Congrats
adam0311 is offline   Reply With Quote
