01-19-2013, 12:37 PM | #1 |
Drives: 2010 camaro ss Join Date: Nov 2012
IP access blocked?
I have to view this site from my cellphone at home, ever since I moved into a new neighborhood. Can anyone shine some light on this and possibly fix?
01-19-2013, 12:44 PM | #2 |
Drives: 2014 2ss/RS 5th gen Camaro #2 Join Date: May 2012
I would remove your Ip asap, and only provide it to the admins, as they are the ones that can fix it.
01-19-2013, 01:30 PM | #3 |
Moderator.ca
Sometimes we block IPs of spammers or members who have been banned repeatedly. If you recently moved, it is possible that you could have been caught in the crossfire, so to speak. Its happened before. I'll let Tran know, as he's the only one who can ban or un-ban IP addresses.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
01-19-2013, 09:22 PM | #4 |
I'll try him, thanks!
01-19-2013, 09:29 PM | #5 | |
Moderator
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
01-25-2013, 04:23 PM | #6 |
Drives: 2013 Camaro 2SS/RS Join Date: Jan 2010
OPTIONS:
1. Connect using a proxy/portal service that masks your WAN IP. 2. Connect to a VPN with split tunneling (ENA) disabled. Force all port 80 traffic through the tunnel. 3. If you have multiple WAN IP's, choose a different IP in your subnet assigned by your ISP. Pass all traffic outbound through your new IP with a dynamic source NAT rule over the new IP. 4. Powercycle your modem and see if your ISP assigns a new IP. 5. Cell Phone tethering. 6. Crack a neighbors AP and use their internet. ========= TOOLS: http://www.barracudalabs.com/results.php http://www.mxtoolbox.com/ ======== Most likely what happened is your IP was probably blocked based on the subnet, meaning an administrator went to block someone who was banned/spammed that originated from very similar IP's within the same subnet and ended up blocking the entire subnet. Example: Your IP: 172.16.1.100 Admin Blocked: 172.16.1.0/24 or 172.16.1.* -Brought to you buy your friendly neighborhood Barracuda Certified Security Engineer. |
