11-16-2021, 05:49 PM | #1 |
Drives: 2018 Chevy Camaro SS 1LE Join Date: Aug 2019
1LT engine eater (6 total)
i have less than 11,700 miles on 2 1LE's and have replaced under warranty a total of 2 original engines and 4 crate engines under warranty...4 engines 2018 and 2 in my 2021...hard to believe but very true...thanx...glenn...Natalia Texas
11-16-2021, 06:05 PM | #2 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
Dam.. under what conditions?
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
11-16-2021, 07:53 PM | #3 |
Drives: 2022 Camaro 2SS 1LE M6 Join Date: Nov 2009
Holy moly! Are you draining the engine oil, then only driving at 6000+ rpm? What conditions are causing these? Is it a track only car?
2022 2SS 1LE M6
11-16-2021, 08:21 PM | #4 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Post count...
11-16-2021, 08:29 PM | #5 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
I call BS unless OP confirms this with specifics and/or pictures...
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
11-16-2021, 08:50 PM | #6 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
He tracks frequently and we have chased each other on track at several HPDE events. I have seen the pictures of the destroyed internals from his first 2021 SS 1LE engine. I think it was affected by the bad batch of valve springs. I also crawled under his car at the track to tap on the starter which was working intermittently after the warranty engine replacement because the dealership didn't fully tighten the power wire.
11-16-2021, 11:56 PM | #7 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Wow
11-17-2021, 12:08 AM | #8 |
Drives: 2SS 1LE Join Date: Oct 2011
Probably botched installs each subsequent time...
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
11-17-2021, 05:47 AM | #9 |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
11-17-2021, 08:08 AM | #10 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
At this point it should be a GM buy-back. Or give up on the dealer and get a built motor from a reputable builder.
11-17-2021, 08:30 AM | #11 |
Who Needs to KNOW?
6 engines in total.. if i read that right.
You know car has more than one gear right ?
ing for grip.
11-17-2021, 01:15 PM | #12 |
I am 67 yrs old and track for fun...I will say that I am pretty quick but do not abuse my equipment...my 2021 was an automatic and it only made it 2800 miles w/out race modes engaged...I love Camaro's and just ordered a 2022 1LE...
11-17-2021, 01:19 PM | #13 |
Drives: 2016 1ss camaro Join Date: Feb 2016
lol wtf is this a mustang joke?
11-18-2021, 04:35 PM | #14 |
crate #3 just installed under warranty 11-18-2021 warranty protocall requires 5W30 which is a total joke...i put 0W40 gen2 instead...same engine as 2021 but someone at corporate forgot to upgrade oil requirements for replacement engines...glenn
