01-21-2010, 06:52 PM | #1 |
Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
Billet VS Cast VS Forged
Hey guys I'm trying to learn everything I can about wheels before making a purchase.
I know Billet are cut from one chunk of metal. Cast are poured into a mold Forged are heated and shaped and usually are 2 or 3 piece but what are the advantages and disadvantages of each?
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
01-21-2010, 09:19 PM | #2 |
Price
Cast is the cheapest wheel. they will work on many applications but not great for cars that are put thru the ringer. Billet is the mid line wheel. Better than cast and will hold up better. Forged is the high class custom wheel that gives you many options. These are also a great wheel doing oversized brakes or need a custom fit. |
01-21-2010, 10:01 PM | #3 |
Moderator
Forged quality can't be matched.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
01-21-2010, 10:59 PM | #4 |
Drives: Black SS/RS Join Date: Nov 2009
If you can afford it go with forged. My last car I was impatient and bought cast wheels, and regretted it ever since. Save up and do it right the first time!
Black SS/RS - Magnaflow Comp Series, Eibach Suspension, Roto-Fab Intake
01-22-2010, 09:15 AM | #5 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
Cast wheels are melted aluminum poured into a mold.
Billet and Forged are the same thing, in the wheel industry. "Billet" just means that the wheels are milled out of a chunk of solid material. That material is an aluminum forging, hence the "forged" description. However, there are three different types of forged wheels. 1-piece construction. This means the entire wheel (center, hoops) was one huge chunk of forged aluminum. The entire wheel was machined out of that one chunk. These are usually the lightest in weight, but also tend to have less options in terms of width/offset. 2-piece construction. This means the wheel is assembled from two separate sections, the center and the hoop. The hoop is 1-piece itself, and is the width of the entire wheel. The center is a milled out forged piece, and is welded to the hoop on the backside of the center face. 2-piece wheels have limited widths available, since there are only so many size hoops manufactured. Most wheel makers use hoops from the same few suppliers. Typical max width for a 2-piece wheel is 10" wide. 2-piece wheels can be built with hardware showing, but it is purely for cosmetics since those bolts don't hold anything together. 3-piece construction. These wheels are made with 3 separate sections. Center, outer hoop, and inner hoop. All three sections are bolted together in the middle, to the face. 3-piece wheels offer the most available width increments and offsets, due to their more customizable construction method. Also the most expensive, due to additional labor required to hand-assemble the wheel. My personal suggestion is to go with 2-piece wheels if you can live with the limited widths (typically 8.5" fronts, 10" rears for the Camaro). They look identical to 3-piece wheels, weigh the same, and cost less. But, if you wish to go wider, then the 3-piece is required. If you want chrome lips or custom painted lips, the 3-piece is required.
Fquick.com/NineBall
Similar Threads | ||||
Kenne Bell 2010 camaro kits 2.8, 3.6, 4.2 available | redsap05 | Forced Induction - V8 | 265 | 02-01-2010 03:04 PM |
cast vs. forged | ssmike | Wheels and Tires Talk Sponsored by The Tire Rack | 14 | 01-08-2010 08:29 PM |
Wheels! Your Camaro needs forged wheels. | Nine Ball | Wheels / Tires | 42 | 12-21-2009 10:51 AM |
360 forged (forged dist.) nightmare!!!!!!! | blackedout010 | Vendor and Seller review / feedback / experiences | 27 | 12-17-2009 02:54 PM |
