07-17-2014, 10:00 AM | #1 |
Nitrogen filled tires??
So I bought my new 2014 2SS/RS on July 2 and today I took notice of the tire stem covers.
They say "N2"!?! I didn't know these ties were nitrogen filled??? How cool! Anyone else?
2014 Summit White 2SS/RS, L99
CAI by Cold Air Inductions, Inc with Strong MAF Sensor / Borla ATAK Cat-Back Exhaust / SOLO Performance High Flow Catalytic Converters / SOLO J-Pipes / Vitesse Throttle Controller / Apex Catch Can / Vmax Ported Throttle Body / Range v8 AFM Disable Module by Range Technology / SLP Fade to Black Side Gill Decals / APEX Washer Replacement System and CAI Scoop / BMR Front and Rear Sway Bars / BMR Rear Trailing Arms / BMR Front End Links |
07-17-2014, 10:04 AM | #2 |
Drives: 2011 IBM 1LT w white Rally Stripes Join Date: Aug 2012
In colder climates, Nitrogen filled tires are a good thing. Nitrogen leaks out of rubber much more slowly than regular air. In warmer climates, like Texas where I am, Nitrogen filled tires are a waste of money. There are a few places that try to sell them down here at $100 a pop.
07-17-2014, 10:05 AM | #3 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
That would be nice I love nitrogen fill.
07-17-2014, 10:12 AM | #4 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
I keep my tires at 78% nitrogen year round
07-17-2014, 10:13 AM | #5 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
Nitrogen is good for track performance as the purity of the gas (less moisture, other contaminants) mean less expansion/contraction under extreme temperature conditions. A regular tire filled to 35psi might increase to 41 or so PSI with track use, but when filled with a high purity of N2, would only increase to maybe 37 or 38 psi. N2 and regular air have similar expansion/contraction qualities, but all the other junk in typical compressed air (moisture, contaminants) cause the increased pressure fluctuation.
07-17-2014, 10:14 AM | #6 |
Let's go Rangers!
07-17-2014, 10:25 AM | #7 |
Pretty cool. I was just surprised to see that. I don't even think the dealer knew about it!
07-17-2014, 10:27 AM | #8 |
That's insanely cheap! The Jiffy Lube in Lewisville was the one charging $99 for all four tires.
07-17-2014, 10:34 AM | #9 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
07-17-2014, 10:37 AM | #10 |
My home compressor can separate N2 out of the air and provide a 78% (not really as efficient as industrial) mix for my tire fills ... what whaaat!!???
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
07-17-2014, 10:45 AM | #11 |
Drives: ? Join Date: Sep 2012
Wife's minivan got tires at COSTCO and they use nitrogen....and will refill for free if the tires get low.
07-17-2014, 11:16 AM | #12 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
That is typical of a Class M planet.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
07-17-2014, 11:36 AM | #13 |
S & S or Firestone here charges $5 per tire.
Ordered 6/19/09 Black on Black 2 SS Delivery 10/14/09! Added CAI, Heritage Grill, DRL Plug and Play Harness
07-17-2014, 11:37 AM | #14 |
Drives: 2012 ZL1 Join Date: Feb 2014
