Old 01-15-2011, 08:55 PM   #757
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
gonna have to trailer it. won't drive over 1200rpm without feeling like it's detonating :(
Eve ('00 FRC): hot-air intake
Old 01-15-2011, 08:57 PM   #758
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
WOW! Can his tune be off this bad??? It just seems like it might be something else in addition to needing a tune.
Old 01-15-2011, 09:17 PM   #759
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
I hope you get it worked out, Like to see a good end to the install for PQ.
Old 01-15-2011, 09:33 PM   #760
Russell James
Russell James's Avatar
That almost sounds like the MAF isn't reading the airflow. I've worked on a few cars that knocked like crazy off idle, and they turned out to be bad MAFs. On some cars you can turn the key off, unplug the MAF, then restart the engine. And if it idles perfectly with the MAF unplugged, something is wrong with the MAF or wiring. The ECM will use a default value if the MAF is unplugged. I've never tried that on a Camaro, but it has worked on every other car I've suspected a bad MAF.
The arrow on the MAF is pointing toward the engine? It can go in backwards.
Old 01-15-2011, 09:43 PM   #761
BackinBlackSS/RS
Go Blue!!!!!
Check this as well with the maf. You might be surprised. It will only take a second to check.
http://vararam.com/camaro.html
Old 01-15-2011, 09:43 PM   #762
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 01-15-2011, 10:02 PM   #763
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
@PQ; Bro' take the vehicle in to a specialist. You wouldn't want to keep tinkering and blow the engine. A few hundred bucks to get it sorted out and tuned right is better than $10k in engine repairs, unless of course your next step is to upgrade the internals anyway. LOL
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
Old 01-15-2011, 10:06 PM   #764
Russell James
MAF problems can be tough to diagnose too, often don't set a code. The ECM just gets a wrong reading, and calls for the wrong fuel (way too lean if it's not reading the air flow) and the engine will just stall or detonate unexplainably when you crack the throttle and the engine gets more air not seen by the MAF.
I'll wager 37 cents the MAF is either in backwards or a wiring problem to the MAF.
I would try unplugging it with the key off, then restart, and see if it will idle stable with the MAF unplugged.
Old 01-15-2011, 10:10 PM   #765
2SSRS@Gen5diy
PQ do you have a way to test all the fuse's for the fuel pump or the ECM, You may have blown one and don't know it.
Old 01-15-2011, 11:39 PM   #766
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I agree. Magnuson told me to ziptie the actuator open and try to ease it to the tuner. And if I notice any detonation to not drive it.
The other night when I was resplicing the wires I had to take the intake loose so i had to unplug the MAF sensor. I forgot to plug it back in and found out because it started but immediately died. The sensor is in the correct flow direction. The arrow is correct. If it wasn't I would have known 6 months ago.
Old 01-15-2011, 11:42 PM   #767
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
werd
learn the ways fo the tune you must....
Old 01-16-2011, 12:03 AM   #768
PQ
Booooosted.
PQ's Avatar
I'll check. But it's been working in this intake for 6 months.
Ya. I can pull them and look.
Old 01-16-2011, 12:05 AM   #769
GTAHVIT
Blessed
GTAHVIT's Avatar
FUUUUUUUUUUUUUUUUUUUUUUUUUUSE PUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUULLLLL
Old 01-16-2011, 12:18 AM   #770
PQ
Booooosted.
PQ's Avatar
Free for all.
I got fuses I haven't even pulled yet.
Where to get engine cover modified after a Maggie install? 1meanss Cosmetics and Lighting Modification Discussions 5 03-05-2011 09:00 PM
Another Maggie install .... Luvpilot Forced Induction - V8 9 06-20-2010 09:00 PM
maggie install, hose routing suggestions please n2oSS Forced Induction - V8 6 05-31-2010 03:59 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
