02-05-2013, 01:08 AM | #1 |
Drives: A Purty Pony Join Date: Oct 2012
NEW TIRES HELP!
Hey guys I'm looking to get new tires right now, what do you think of this set up? Firestone Firehawk GTs (245/45r20) I have 20' oem rims btw
02-05-2013, 07:39 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
well remember, the fronts and the backs are different sizes.
seeing as you too have a V6, and are in Texas.....I would recomment the General GMAX AS-03, good price, they wear good, are fairly quiet, and LAST. I've had them on my car for 10,000 miles and they still look like new.
02-05-2013, 01:01 PM | #3 |
Drives: '11 Cammed LS3, '14 Scion FRS Join Date: Dec 2011
Had the Firehawk GTs on my Mustang... they sucked.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP |
02-05-2013, 06:23 PM | #4 |
Wait so running (245/45r20) on all fours isn't going to work? Because the dude said their take offs from a 13' challenger.
Selling for pretty cheap like 500 for all 4s |
02-05-2013, 09:11 PM | #5 | |
There are a LOT of us that are running the rears (20 x 9's w/ 275's) on all 4 corners.
02-05-2013, 09:59 PM | #6 | |
02-05-2013, 11:00 PM | #7 | |
02-06-2013, 06:42 AM | #8 |
a set of tires or the wheels?
you can get the tires at both Tire Rack or Discount Tires.....they run about $200 each. The wheels, you would only need two, seeing as how you have two already....check eBay, or the market here.
02-07-2013, 08:32 PM | #9 |
Nuke, I'm planning to get 275/35/20 for my rears, is that a good setup? instead of being 275/45/20. Oh and their falken brand
02-07-2013, 11:22 PM | #10 |
Drives: '69 SS Convertible Join Date: May 2009
You should look into the BFG Comp 2 or the new Mickey Thompson streets. Don't go with the cheapsest tires you can find. Spend a little more and get a good brand. You should also stick to the 275/45/20 IMO.
BTW: I've been running 20x9 with 275 on all 4 corners for over a year now. That's the way to go if you can. I picked up some used polished rears for $125 ea and sold my fronts for like $80 ea.
Build Journal |
02-08-2013, 07:57 AM | #11 |
Slow Race Vert
Drives: 2011 2LT Vert Join Date: Feb 2012
Here this might help !
http://www.camaro5.com/forums/showthread.php?t=62838 I have used this several times when Buying tires.. I finally settled with 315/35/20 in the rear and 275/40/20 in the front. But I have after market wheels with 11 rears
02-10-2013, 11:40 PM | #12 |
So I just checked the boxes my rims came in and all 4 of them are 20x9.
02-11-2013, 06:34 AM | #13 |
Jessie.....the way to go would be to go with 275/40/20's that is the stock size for our 20's
02-11-2013, 11:24 PM | #14 |
I think all four of my wheels are running so 20x9. That means they're staggered right? So I go 275/40/20 on all fours? Sorry if these questions sound stupid lmao. Im clueless
