Old 07-10-2010, 11:39 AM   #1
sir5er
sir5er's Avatar
Drives: 2SS 2010 Camaro, 2007 Acura TL
Question Remove gfx without damage?
Has anyone installed their gfx and removed it without damage? If so, were you able to put it back on? I have mine on but think I may want to paint it but want it taken off of the car first. Plus I don't like the round exhaust tips showing through the square openings of the rear portion. I want to have square tips installed. I was told it has to be removed in order to do that. Any tips?
sir5er is offline   Reply With Quote
Old 07-10-2010, 12:00 PM   #2
shockandawe
shockandawe's Avatar
Drives: 2014 Z51 Corvette
Use a hair dryer to soften the tape,pull gently to remove and clean off remaining residue with GOOP.
shockandawe is offline   Reply With Quote
Old 07-10-2010, 12:03 PM   #3
HzMajesty
HzMajesty's Avatar
Drives: 2010 2SS/RS Blk/Blk
Send a message via MSN to HzMajesty
this will be the most heart aching thing you will do...
as shockandawe said... heat it up... but be careful not to damage paint... you will leave residue behind.. and it will be a PITA to get it off with anything... so be patient... when u loose patience u will become reckless and end up scratching ur clearcoat... been there done that... :(
SHOCKWAVE - 2SS/RS/M6 - Blk/Blk
JRE Tuned - ARH LT 1-7/8 w/Cats - JRE Rear 4.11 - Borla "S" Cat-Back - CAI by CAI - H&R drop - HURST Shifter - BMR Tunnel Brace; 4 Point Brace; Adjustable Toe Rod; Rear Trailing Arms - Sphon Control Arms - MTI Racing w/Fire Sleeves - Stealth Ambers - GTS Tails - Phantom Grille - Concept LED Sidemarkers - Blacked out logos - Hotchkis Bars & End links - BMR Front Driveshaft Loop (install soon) - BMR Subframe connectors (install soon)
http://www.cardomain.com/ride/3813191#
HzMajesty is offline   Reply With Quote
Old 07-10-2010, 12:40 PM   #4
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
uh, doesnt the OP mean Ground Effects? FX usually stands for Effects... GFX doesnt mean "Graphics"... So i dont think the OP was talking about getting rid of stripes... lol.
Correct me if im wrong =p
-EDIT: I don't have GFX myself... but i assumed it was bolted on, instead of adhesives.
jagan323 is offline   Reply With Quote
Old 07-10-2010, 01:42 PM   #5
zerox
zerox's Avatar
Drives: 2010 2SS RS Bumblebee
Nope these are adhesived on
zerox is offline   Reply With Quote
Old 07-10-2010, 07:25 PM   #6
R6P
R6P's Avatar
Drives: 2010 Camaro
The rear panel is mostly attached with 3M tape, the front splitter is rivited & taped.
If everything is well secured, at this point I'd say have them painted on the car.
As far as the exhaust, you can probably change the tips without removing the rear GFX maybe even unbolting the exhaust from the cats & hangers and shifting it forward if needed.
R6P is offline   Reply With Quote
Old 07-10-2010, 11:37 PM   #7
Sevn86
Sevn86's Avatar
I had thoughts about selling my camaro too...but i want to trade it in for a jeep wrangler unlimited Rubicon...but then i stop and think about it and just looking at my camaro i change my mind...
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 07-10-2010, 11:46 PM   #8
sir5er
sir5er's Avatar
Thanks I will try that
Old 07-10-2010, 11:55 PM   #9
Alysha
Alysha's Avatar
Drives: Camaro SS/RS, Suburban, & Caddy CTS
Just had mine removed, painted, then put back on a few weeks ago. No problems, but the dealer did it, not me.
Alysha is offline   Reply With Quote
Old 07-11-2010, 12:06 AM   #10
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
The GFX are attached with tape and plastic rivets. Even the rear diffuser has some rivets in it. You don't need to remove the rear diffuser to replace the exhaust tips--I've done it with mine. My dealer wants $1,300 to remove, paint and reinstall my GFX. I've thought of having them painted on the car, but I think that's second best. Even though I think leaving them on the car will avoid potential of having them fall off. I haven't gotten an independent bid for removal/reinstall and painting from anyone else, but I'm not crazy about spending $1,300 so I've held off.
Meh
My 5th is offline   Reply With Quote
Old 07-11-2010, 02:19 AM   #11
DaveT
DaveT's Avatar
Drives: 2010 2SS CGM LS3
You can remove the bezels in the GFX to monkey with your tips. That's what I did. I put the 4.5" tips on my Solo, but had to cut the tubes down a re-tack the tips. Bezels are kind of a PITA but much better than removing the whole rear piece. I had a paint shop quote me $1k to remove, paint and re-install my GFX. I don't think he knew what he was getting in to. My car is CGM, so I left it gray.
DaveT is offline   Reply With Quote
Old 07-11-2010, 07:13 AM   #12
paul2010
paul2010's Avatar
Drives: 2012 ZL1 #1278
My dealer said they could take them off no problem. A lot of people are having trouble keeping them on. If the dealer don't let them sit for 24hours after installation they will probably just fall off anyway.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout
2011 2nd Place Fastest 4 5th Gen LSX Shootout
paul2010 is offline   Reply With Quote
Old 07-12-2010, 12:31 AM   #13
zerox
zerox's Avatar
That is a gorgeous camaro I am very much considering those rims next year.
Dealer Prep & scratch 2010 Black SS Paul alienn Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 26 02-20-2010 02:42 PM
Updated GFX Mayhem Cosmetics and Lighting Modification Discussions 13 09-04-2009 12:46 PM
Engine cover came in...GFX install sucks. 2032Ceta 5th Gen Camaro SS LS LT General Discussions 0 08-19-2009 07:20 PM
What Muffler desine/type would fit the GFX best? Li0nel1234 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 07-26-2009 09:23 AM
