04-14-2010, 08:52 AM | #1 |
Drives: Truck Join Date: Apr 2010
Do you need an alignment for just anti-sway bars and end links?
I know you do if you're putting in new springs, but what if you only install new anti-sway bars and end links?
Thanks! |
04-14-2010, 09:09 AM | #2 |
Drives: 2010 Camaro Join Date: Mar 2010
No you dont need an alignment.
04-14-2010, 12:18 PM | #3 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
04-14-2010, 12:36 PM | #4 |
Thanks for the replies!
My car is currently being built but as soon as I get it, I'm going to do anti-sway bars and end links upgrades. Will probably do springs later. |
04-14-2010, 09:39 PM | #5 |
Drives: 5th Gen Rental Join Date: Aug 2007
We all agree. LOL
No alignment required for doing sway bars, unless you are looking to improve handling by having a performance oriented alignment performed thanks mike dms |
04-15-2010, 01:05 PM | #6 |
Drives: 1st through 5th gen Camaros Join Date: Sep 2009
If your car was well aligned before the swaybar install, there should be no reason to realign it. We do recommend aligning brand new cars however, as the factory settings are not designed for the high performance driver.
Similar Threads | ||||
Status of Pedders Sway Bars | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 53 | 05-07-2010 02:42 PM |
End links of sway bars | moultron | Suspension / Brakes / Chassis | 8 | 03-05-2010 01:28 AM |
Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
Pfadt-ening things up Phase 1: Sway Bars | robertway | Suspension / Brakes / Chassis | 14 | 02-11-2010 03:57 PM |
