08-24-2011, 06:27 PM | #1 |
Drives: 2010 SS/RS 6 Spd Manual IOM Join Date: Aug 2009
Drivers Seat Leather Coming Loose
Hello,
Just wondering if anyone else's factory drivers seat leather is continuously popping out of the track under the seat at the front left making it show the foam on the side? The plastic track that runs across a bar all the way across holds the leather seat cover comes undone every time I sit in the seat and when I get out I can see the foam on the side and I reach under the seat and roll it back into place and I tuck the leather back in place between the plastic on the outside of the seat . Almost 15,000 miles on the 2010 SS/RS and I don't think this should be happening already, I'm 165 lbs so I don't think I'm stressing the seat that much. I'm not upset really, I'll take it to the dealership to see what they say but I'm just wondering if this is common? |
08-24-2011, 06:58 PM | #2 |
"Catharine"
Drives: '11 2SS/RS LS-3 IOM/IO vert Join Date: Mar 2011
No problems here. But have only put 1100 miles on the car since I got it in June. My wife is really heavy, but so far the passenger's seat is holding up.
08-24-2011, 07:07 PM | #3 |
Drives: 2011 2LT RS White/Orng Strip Join Date: Feb 2011
No problems here. Sounds like a warranty issue.
08-24-2011, 09:42 PM | #4 |
Retarded One-Legged Owl
Drives: 2010 Black Camaro 2SS Join Date: Oct 2008
Mine does. The dealership is ordering me a whole new leather lower seat cover. We'll see if that fixes it...
08-24-2011, 09:44 PM | #5 |
Switchin' n Twitchin'
Drives: 2011 Camaro Join Date: Nov 2010
I am not childish, you're just being a poopy head!
08-24-2011, 10:45 PM | #6 |
Junkie
i had this issue h/o i will post the thread link
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
08-24-2011, 10:46 PM | #7 |
Junkie
08-25-2011, 07:52 AM | #8 | |
The OP is referring to the clip under the seat at the front keeps coming unsnapped from the seat frame...
08-25-2011, 08:44 AM | #9 |
Drives: 2010 2SS/RS M6 Black/Black Join Date: Apr 2009
Mine does this... first time i reached under to fix it I got a nasty cut from a sharp wire tie that was under there
Pittsburgh Automotive Photography Black on Black 2SS/RS w/ white stripes Dynomax 3" Bullet Catback, CAI Cold Air Intake |
08-25-2011, 10:38 AM | #10 |
mine does the same exact thing, just noticed it really a few weeks ago. im 200 lbs so i just thought i was crushing it but if its happening to you too maybe i should take it to the dealer
B-Rex 2011 2SS/RS LS3 Hurst, LG, C.A.I., Flowmaster, Pfadt, Pedders, U.S. Gear/Axle Tech, LPW, SJM, Nitto, Nitrous Outlet, ZEX |
08-25-2011, 11:11 AM | #11 |
RUSH TWO
Drives: 2014 Camaro 2SS/RS Join Date: Aug 2010
I had the same thing. Dealer replaced the lower seat cover. They broke the plastic side panel then had to order it and replace. Finally fixed.
08-25-2011, 12:04 PM | #12 |
I'm ~165lbs... noticed it shortly after buying the car. It really doesn't bother me but next time I have the car in I'll have them look at it.
08-25-2011, 06:21 PM | #13 |
I'll take a couple pics next time I drive the car and it happens. I'm sure the dealer will take care of it, Fairway Chevrolet is a great dealership from what I have experienced so far.
08-29-2011, 07:07 PM | #14 |
Ok, I drove the car today to get a few small dings out that were bothering me every time I looked at the car and I took a pic of the seat. By the way the guy that has a stand set up at the gas station on base did a phenomenal job on the dings and I couldn't be happier, if your a military member or are in the local Las Vegas area pm me and I'll give you his info.
Thread Tools | |
Similar Threads | ||||
Add HUD to your 2010 | 2SSRS@Gen5diy | Camaro DIY & HOW-TO instructions & discussions | 1993 | 03-30-2019 08:02 AM |
Cut drivers leather seat | djmikehop | 5th Gen Camaro SS LS LT General Discussions | 10 | 06-10-2011 07:43 PM |
Exposed foam of seat under the drivers seat / possible seat cover to short/tight | 2010 Bumblebee | 5th Gen Camaro SS LS LT General Discussions | 5 | 08-28-2010 05:12 PM |
Driver's Seat Bolts Part Number? | Kendell347 | Interior Parts & Accessories | 1 | 06-13-2010 05:42 PM |
