05-18-2018, 01:01 PM | #1 |
Jim
Drives: 2013 Black 2SS 1LE Join Date: Apr 2013
Emissions testing
I have a 2013 2SS 1LE Camaro. It is due for emissions testing in the next few weeks.
Some questions. Nothing was done to it except and Air Raid installed Cold Air intake. They put it on the dyno and got about 18 added hp to the wheels. They claim that they checked it and it will pass emissions. Question: Any thoughts or experience whether or not the cold air intake will screw up the emissions test. Also I have a mild to wild switch on the car and its always set to wild. Question: will that affect the emissions test and should I put the switch back to stock? Thanks Jim
Jim's Mongoose, 2013 1LE with Airraid CAI and PTB, mild to wild switch, and Vitesse throttle controller.400RWHP on Mustang Dyno In Phoenix, AZ on a 75 degree day.
05-18-2018, 01:12 PM | #2 |
Hard to want.
Drives: 2020 red hot 1SS 1LE Join Date: Aug 2017
You will be fine. Most places will only plug in your car. No codes = passing.
05-18-2018, 01:39 PM | #3 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
x2. CA seems to be the only state that requires CARB certified plaques and modifications. As long as you haven't REMOVED emissions related items (or at least it doesn't obviously look like you did), and you don't have a CEL, you'll be fine.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-18-2018, 02:28 PM | #4 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
No problem ,if you have cats and no check engine light on , and no readiness codes your good to go . That CAI should pass the tamper/visual inspection .Leave your switch on mild for inspection.Gordon Darby and most if not all their employees are idiots . Check out the rip off report on Gordon Darby in Mesa and never let them put an older vehicle of yours with a clutch on the rollers .
OLD GUY FLYING FAST AND LOW
05-18-2018, 06:52 PM | #5 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Your fine. I'll pass next year with an S/C, no cats, and a solid tune. No CELs of course.....the only vehicle I've ever had visually inspected was my diesel truck. They always looked underneath for the cat on that truck....Never seen them do a visual on one of my cars. Just an OBD hook up and tail pipe sniff at most.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
05-18-2018, 07:30 PM | #6 |
Jim
Thanks guys
Thanks guys for all the feedback and the help.
Jim
05-19-2018, 12:50 PM | #7 |
Drives: 2014 white 2ss rs 1le Join Date: Mar 2017
18 rwhp from an air intake?
05-19-2018, 04:57 PM | #8 | |
Diesel test — a car smoke test that evaluates the density of a diesel vehicle's smoke. Note: A visual smog certification test known as "tampering" may also be performed on an inspected vehicle in order to make sure that various emission control components were included by the car manufacturer, such as the operational air pump, the catalytic converter and the evaporative control system.
05-19-2018, 05:09 PM | #9 |
Drives: 2015 Camaro SS/1LE Join Date: May 2015
Yep. Most of the big name cold air kits do right about that.
CreeperRS got 16 rwhp/10 rwtq. His shop baselined his otherwise stock 1LE, swapped in the Z/28 cold air kit and dynoed again. Here's his post on it: https://www.camaro5.com/forums/showp...&postcount=135
2015 2SS/1LE/RECARO/NPP/RS/NAV
05-19-2018, 05:33 PM | #10 | |
OPTIMISTIC
https://spreadsheets.google.com/ccc?...ZNVI5aVE&hl=en
05-19-2018, 05:47 PM | #11 | |
Anyways, decent power gains can be had with a cai w/o tuning.
05-19-2018, 05:50 PM | #12 |
12 peak check the chart , and with a stock tune. Ted did the fairest most comprehensive test at the time and all on the same dyno . Now with a ported TB, long tubes ,93 octane and a good sharp tune the numbers get much better with a good cai.
05-19-2018, 05:54 PM | #13 |
He showed some at 13 - 15 gains and an 18 gain with his scoop. No tunes.
05-19-2018, 05:59 PM | #14 |
look at the last box on the right of the chart , tuning recommended on the big hp numbers
