09-06-2014, 09:26 AM | #1 |
Quad tip exhaust question
I just bought some quad tips to go with 1le diffuser, and I have stock V8 exhaust on my V6. My problem is the shop I tried to have tips installed said the setup wouldn't work so my question is can anyone recommend an axle back system or mufflers that will work with v8 pipes that either already have quad tips or can easily have quad tips welded on. I have searched but no one's post that I read have this setup. Thanks
09-06-2014, 09:33 AM | #2 | |
Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
http://www.camaro5.com/forums/showthread.php?t=343362
09-06-2014, 01:34 PM | #3 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I always thought the MRT's looked like a natural for quad tips. In fact have posted on here before they should market a set for the 2010-14's.
They'd sell a bunch of them if folks just needed to replace the rear diffuser and bolt'em on! These are the MRT 2's My shop successfully put quads on my Borla Touring cans. I don't think there will be room to keep any stock (non-npp) mufflers though. |
09-09-2014, 04:07 AM | #4 |
appreciate the advice, looking into these two
09-11-2014, 09:35 PM | #5 |
Drives: 2011 Camaro 2LT IBM Convertible Join Date: May 2013
I'm curious as to what the shop gave for a reason that it wouldn't work?
...........................................2011 2LT IBM Convertible
09-11-2014, 11:01 PM | #6 |
I have cherry bomb extreme mufflers on mine. They had to hang the mufflers a bit odd but they got them to work. The only problem I could see is depending on how long the mufflers are, Beacuse the pipe has to make a pretty sharp bend to come out the rear at the right angle.
Current 2022 Wild Cherrry 2SS; Recaros, NPP, 5 Split Spoke Polished Rims, Satin Black Package
Ordered 7-11-2023 1100: Riptide Blue 2SS, Not Built 2023 Red Hot 1LT RS V6; Sold 2010 VR 1LT RS; Sold |
09-11-2014, 11:14 PM | #7 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Your tips and exhaust are not the problem; your shop is. Find a new mechanic, one who is competent...
A simply dual tip with a Y will suffice so long as it not too long, about 8-12 inches will be fine. |
09-12-2014, 09:49 AM | #8 |
KaBoom1701
I just bolted on a NPP system yesterday with no problem. Easiest mod to do with only 8 bolts... Just waiting for the 1LE diffuser to come in today to finish it off.
Mods:
09-17-2014, 01:52 PM | #9 |
Drives: 2010 Chevy Camaro 1LT Synergy Green Join Date: Jun 2012
Just had this done on Saturday - I have SS Pypes Cat Back Exhaust - 2.5" all the way back - Tips were just welded on, no issues. 1LE diffuser went on with no issues. Perfect.
09-17-2014, 04:52 PM | #10 | |
Jus' Cruzin
Drives: 2017 Camaro 1SS Krypton Green Join Date: Oct 2012
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark |
09-22-2014, 09:22 AM | #11 |
Drives: 2011 Camaro Join Date: Apr 2012
^ where did you get the tips?
09-27-2014, 06:57 PM | #12 |
I bought my tips off ebay(searched Camaro Exhaust tips), and I ended up cutting the suitcases off and putting on some Dynamax Bullet mufflers and everything came out great will post pics later.
09-27-2014, 07:19 PM | #13 |
Jus' Cruzin
-Howard Stark |
10-06-2014, 07:55 PM | #14 |
Slow Race Vert
Drives: 2011 2LT Vert Join Date: Feb 2012
I did the NPP as well, just struggling with the NPP in a box and how to hook it up on the vacuum line. Kaboom sent you a message
