08-10-2011, 12:41 PM | #1 |
DIY - Paint V6 Engine Cover
So everyone with a V6 knows the engine cover has got to be changed, and since its $$$ to get a new one, I decided to paint it...I used
[IMG]file:///Users/Matt/Downloads/photo-7.JPG[/IMG] I removed the cover, and since my plan was to paint the sides white, and leave the middle black, I was going to clear coat everything when I was done, including the plastic...so because I was clear coating everything, everything had to be sprayed with Adhesion Promoter. This eliminates all the need to sanding, it helps the paint stick... So once you do 2/3 coats of Adhesion promoter, then tape. Take your time with this as it will determine the outcome. Use a razor to get the lines you need... Heres mine tapes off: Once its tapes however you want it, begin spraying. I used High Temp paint...do 3/4 coats of this, make sure your applying evenly... Once you've done your 3/4 coats, let it dry for at least an hour, and carefully remove the tape...Once the tape is removed, you can begin to clear coat. Same as the others, 3/4 coats a few minutes apart.... This is really a great, simple cheap mod to our V6 engine bay...total cost, about 20$. It looks great, any questions PM me!
2011 Summit White LS , 30% Tint, MRT v1.0, Roto Fab CAI, 10 inch Infinity Sub in Stealth Enclosure, Chrome Bowties
MY Build: http://www.camaro5.com/forums/showthread.php?t=160486 |
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
How to Choose the Best Car Cover for Your Camaro | Junkman2008 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 27 | 02-27-2015 03:10 PM |
F/S Stock OEM V6 Engine Cover | mac5 | V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 2 | 02-03-2011 08:37 AM |
Car Cover | domano 68 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 19 | 05-21-2010 09:51 PM |
FS: V6 Engine Cover ($40 +shipping) | tradosaurus | Exterior Parts & Accessories | 6 | 05-13-2010 06:49 AM |
