Old 05-13-2016, 04:33 PM   #1
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
How METH is too much???
OK so I have a single turbo setup (details in my sig) and currently running a single nozzle meth system. car runs great, but I was thinking about upgrading to a dual nozzle meth setup. I know I will have to retune WOT, but is there a point when your spraying to much meth? My thoughts are more octane the better I'm running 100% meth, any input would be great.
scv_guy is offline   Reply With Quote
Old 05-13-2016, 06:26 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
No need for a second nozzle till your up past 800whp.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-13-2016, 09:14 PM   #3
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
Agreed. OP, what are the details of your built trans?
Unavowed is offline   Reply With Quote
Old 05-13-2016, 11:40 PM   #4
kevin87turbot
kevin87turbot's Avatar
Drives: 2012 Camaro 1SS with Turbonetics
I have the same setup as you. I chose the dual nozzle meth kit so that the additional meth would supplement my fuel system. I've only got a ZL1 pump and am pushing it close to its limit. It won't hurt to have the additional meth there as long as you're tuned for it.
2012 1SS...in the 10's...but not fast enough yet.
kevin87turbot is offline   Reply With Quote
Old 05-14-2016, 03:18 PM   #5
1KillerSS
1KillerSS's Avatar
That is really not a very smart way to do it, better getting a BAP. You don't want setup to "depend" on meth. You want it to help with IAT's and detonation, not because your running out of fuel. If your meth fails then....
Build thread
Old 05-14-2016, 03:35 PM   #6
scv_guy
scv_guy's Avatar
The trans build was pretty straight forward
Tig welded both TWS, billet shafts and Alto red eagle clutches, and new billet pump. The only factor part used was the transmission case.
Old 05-14-2016, 07:57 PM   #7
Unreal
Drives: 2006 Z06
No need for dual until 850+rwhp. Even then I would just do dual 10s instead of a 10 and 15.
Nick
Corvette Z06 -1200ish rwhp
Old 05-14-2016, 09:10 PM   #8
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Never understood why people spend so much money on a turbo or blower setup, and then cheap out on a zl1 pump. If that pump fails and your tune/WOT AFR is meth dependant, your motor is gone.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 05-14-2016, 09:25 PM   #9
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
Using meth doesn't mean you went cheap on the fuel system. FI can make a lot of heat so you need it to help keep IAT's down. And some want to stay with pump gas. On 91-93 you can buy the biggest FP you can find and its not going to help with the octane. I have a Squash system in my car and I still run meth. If I switched to race gas I would just use it to cool.
Nitroman28 is offline   Reply With Quote
Old 05-15-2016, 12:16 PM   #10
1KillerSS
1KillerSS's Avatar
Agreed, however a single nozzle system can manage all of that until your pushing past 800whp. No need for dual, IMO it just creates a meth dependent engine.
Build thread
Old 05-15-2016, 03:59 PM   #11
GetYouOne
Drives: 2012 2SS/RS
Just went with the alky control with AIS trunk tank. Single nozzle setup.
GetYouOne is offline   Reply With Quote
Old 05-15-2016, 04:44 PM   #12
Rdunn
Really, Really Fast
Rdunn's Avatar
im still running a single nozzle at 1100rwhp
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 05-15-2016, 04:50 PM   #13
Nitroman28
Nitroman28's Avatar
Now for the single to dual nozzle. Single can put out plenty of meth. I switched to a dual for a new setup with #10 nozzles and it's a lot of meth. Going to remove one of my nozzles.
Old 05-15-2016, 05:20 PM   #14
1KillerSS
1KillerSS's Avatar
I didn't mean to say that you "had" to go to twin after 800. I should have clarified that. That just proves my point though.
Plus you have Dave Steck tuning on your car.....that's just not fair!
Build thread
