09-30-2010, 02:11 AM | #1 |
Drives: Camaro 2 LT Join Date: Apr 2010
Camaro makes a heavy metalic popping sound
Everytime I drive over a bump I hear and feel a loud poping sound that sounds like two big blocks of metal hitting eachother.
Also when i drive on rough roads Any tips? |
09-30-2010, 09:07 AM | #2 |
SS PASHN
Drives: 2010 RJT Camaro 2SS/RS Join Date: Jul 2009
Check everything on the suspension including front and rear sway bars. If you did any suspension work you want to make sure everything is tight. I had the same thing happen and found two connections that had loosened up because of the roads I drive on.
I'm sure there is therapy for this obsession!
SLP Long Tube Headers, Hi Flo Cats, Xpipe with Loudmouth II - Done Pfadt Performance+ Suspension and Camber Kit - Done MGW Short Throw - Done Edelbrock Supercharger - Done AAC Lighting - Done Roto Fab CAI - Done Sinister Carbon Fiber Hood and Rear Spoiler - Done Drilled and slotted rotors-Done Now what else can I do? Coilovers, driveshaft, cutouts...... |
09-30-2010, 10:46 AM | #3 |
Drives: Camaro Justice Join Date: Jun 2007
This is not good or normal. With or without suspension modifications get the car on a lift and have the suspension, drive-line and exhaust checked thoroughly. This check would be covered by GM warranty if you are mod free as I doubt anyone has exceeded the terms for mileage.
10-03-2010, 11:23 PM | #4 |
Fixed, needed a new arm and rear header on the rear left axle
Thread Tools | |
Similar Threads | ||||
CAMARO WIKI | Tran | Wiki | 65 | 12-14-2022 07:23 AM |
Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 02:18 PM |
Camaro SS: All Out Bonneville Unlimited Speed Test | Tran | 5th Gen Camaro SS LS LT General Discussions | 75 | 08-23-2010 02:49 PM |
Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 10:29 PM |
Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 07:05 PM |
