05-16-2010, 08:44 AM | #1 |
Drives: 2010 Camaro 2ss Join Date: Apr 2009
Amsoil transmission fluid
What kind of Amsoil transmission fluid do I need for my M6 2SS?
Do I use this for both the rear differential and the manual transmission? Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 : 1 QUART
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal |
05-16-2010, 09:07 AM | #2 |
Drives: 5th Gen Join Date: Feb 2010
05-16-2010, 10:16 AM | #3 |
I keep seeing that the oil is called Automatic Transmission Fluid. Is there any reason for that because that confuses the heck out of me since I have a manual.
I've also heard that for the manuals, you use the same kind of fluid for the tranny and the rear differential but on that link it shows two different products
05-16-2010, 12:44 PM | #4 |
awesome, time to order
05-16-2010, 08:42 PM | #5 |
Drives: Chevrolet Camaro 1SS Join Date: Mar 2010
Honestly, I tried that rear diff fluid and I'm not sure it actually has the friction modifier. Changed it out and after a few hundred miles the rear started clunking and whenever i turned, it made a rough vibrating noise. Took it to the dealer, they flushed it out and added the friction modifier. Been smooth sailing ever since. The transmission fluid is great tho. Just make sure about the rear fluid :(
- Rico Edit: Just make sure you get the Amsoil Slip-Lock with it. My mistake for not catching it before... Last edited by Mrniceguy633; 05-16-2010 at 08:53 PM. |
05-18-2010, 01:31 AM | #6 | |
Drives: 2010 2SS Join Date: Apr 2010
