07-05-2013, 03:46 PM | #1 |
Drives: 2010 rs/ss black # 10,308 Join Date: Mar 2009
My motor go boom!
Well it wasnt that dramatic. But good ol cylinder 7 gave up on me.
Cylinder 7 is on the left. And for the cylinder itself! couldnt find the piece borken off either Anyways, its time to move on. So this is what i am thinking as far as a setup witll go. Curious if anyone else is running a similiar layout and can provide feedback. so here is my list... *twin precision 6262 rear mounted turbos *weisco pistons-bore 4.07- -11cc dish *callie compstar I beam rods *stock crank *coated bearings all aroudn *ARP studs and bolts all aroudn *full valve train upgrade *ID1000's *aeromotive fuel pump and setup *very mild boost cam *stock heads *Meth injection as far as what else is done to the car it can be found in my build journal here...http://www.camaro5.com/forums/showthread.php?t=138457 So i drive my car a lot, it actually was my daily driver. So I want something that will be able to take the abuse i put it through. My ultimate goal is to pump ~20psi of boost into her. So i am ready for the good and the bad opions. lets hear em.
07-05-2013, 03:51 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
I don't have the exact setup but am using these parts you plan to:
the same Wiseco -11cc pistons Callies I beam rods stock crank coated bearings ARP head studs ID1000s I have a ysi, big cam, meth w/dual nozzles, prc260 heads, and the squash system. I put down 825rwhp on a dynojet BEFORE the bigger cam, meth, and heads. I also added 4# (went from 15.xx to 20) of boost putting me at 20psi at the top so I don't know where I am but I know the car feels faster now and spins the tires easier. I think you will be fine. |
07-05-2013, 04:04 PM | #3 | |
07-05-2013, 04:09 PM | #4 |
Not yet... I am planning an upgrade to some things first because I don't want to break anything on the first outing. I have already broken the stock rear on the street. When I am done, it should run in the 9s easily and get me kicked out of a track because it doesn't have a roll bar yet.
07-05-2013, 04:31 PM | #5 |
thats my exact goal is to be the first Manual in the 9's with stock displacement. I was able to run a 10.99 with only 622whp on stock rear end and suspension.
what did you break on your rear? i shattered my spider gears once haha
07-05-2013, 04:50 PM | #6 |
Drives: 2011 Inferno Orange SS Convertible Join Date: Apr 2012
What do you think caused it to go boom?
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
07-05-2013, 05:00 PM | #7 |
I broke teeth off the ring gear. They were the weak Richmond 4.10s. I was grabbing second gear and CLUNK.
I went back to 3.45s and no issues since but traction is a problem and the biggest savior of my driveline. Gforce 9" is in the works though along with other goodies. |
07-05-2013, 05:13 PM | #8 | |
It is common that cylinder 7 runs a little more lean then the others. So possibly leaned out when i shifted. But realistically i just think its the fact that i was producing well over 650whp on the motor for a long time... and i drive this thing HARD.
07-05-2013, 05:18 PM | #9 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
I lost # 5 myself, broke the top 2 ringlands. The motor Im running now is very very stout and i plan on eventually adding twin PTE6766 turbos. Im just having too much fun with with the D1SC. Im at 14psi
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
07-05-2013, 05:18 PM | #10 |
I am also running billet caps and a posi mod. I want to change it out before I break it. I can sell it to recoup some of the 9" money.
07-05-2013, 05:38 PM | #11 |
Hasbin of Stock Bottom HP
07-05-2013, 05:46 PM | #12 |
Drives: 11 Seconds or Faster Join Date: May 2012
My money is on this guy, sorry OP
Right after that the motor goes boom though |
07-05-2013, 06:01 PM | #13 |
Why thank you . I'm hoping to borrow some DRs and I'm going to a Dig or Roll racing event next week. Get some good roll runs in and hopefully late in the day when it cools down make a few 1/4 passes.
07-05-2013, 06:09 PM | #14 | ||
well if you take a year off then we have a race lol I would agree with you. Because of this happening out of the blue, i wont have the money awhile now. So i would hope he beat me to it lol
