#Camaro6
Old 08-18-2019, 10:41 PM   #1
blackgloves
blackgloves's Avatar
Drives: 1987 Iroc Z/28
Does my car have an exhaust mode?
2019 2SS
I've went to my driver settings on the touch screen and the only thing available is Steering Mode. The switch near the console allows me to change from Ice/Touring/Sport/Track
I haven't seen anything about the exhaust or suspension.
Sorry for the newb questions. Still very new with this car and trying to learn as much as possible
Thanks in advance
Current:
1987 IROC Z28
2021 GMC Canyon Elevation
Former:
2019 2SS (Crush)
1978 Z28
2006 SS/SC Cobalt
2001 Z28
1999 Chevy S-10 Extreme
1972 Z28
1984 Z28
blackgloves is offline   Reply With Quote
Old 08-18-2019, 10:44 PM   #2
rocknss
rocknss's Avatar
Drives: 2017 50th Anniversary Camaro SS
I believe you only have those options if you have duel mode exhaust and magnetic ride control.
2017 50th Anniversary Camaro 2SS
2016 Chevy Malibu LT (wife's car)
2004 Chevy Impala (winter car)
2001 Chevy Camaro SS (sold)
1969 Chevy Suburban (restoration project)
rocknss is offline   Reply With Quote
Old 08-18-2019, 10:57 PM   #3
njdad61
njdad61's Avatar
Drives: 2020 Satin Steel 2SS Coupe
Originally Posted by blackgloves View Post
2019 2SS
Thanks in advance
The main "Mode" switch adjusts how power is delivered, things like throttle mapping, available power, and shift points. I leave mine in Sport unless I'm on the highway for a long stretch. You'll find the steering will loosen or tighten depending on the mode, if you have steering set to automatic. I have that set to Sport as well because I don't like how loose it is in Tour and I find Track to be too tight for daily driving.
You won't have options for exhaust or steering without the corresponding equipment installed on the car (Dual-mode exhaust and magnetic ride control).
  • TPW 8/5/19
  • Built 8/2/19
  • Arrived 8/13/19
  • Home 8/16/19
njdad61 is offline   Reply With Quote
Old 08-18-2019, 11:31 PM   #4
blackgloves
Thank you. I have an option for steering, just not exhaust or magnetic ride control
Current:
1987 IROC Z28
Former:
2019 2SS (Crush)
1978 Z28
2006 SS/SC Cobalt
2001 Z28
1972 Z28
1984 Z28
Old 08-19-2019, 03:01 AM   #5
RLem619
RLem619's Avatar
Drives: 2019 Camaro 2SS A10
As mentioned above, if you have NPP and MRC you can change them in your MODE settings. If they are not in the settings, it's not equipped.
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
RLem619 is offline   Reply With Quote
Old 08-19-2019, 07:28 AM   #6
24v
Drives: 2018 SS
Just look at the back of your car. If you have 2 tail pipes you don't have an "exhaust mode". If you have 4 then you do.
24v is offline   Reply With Quote
Old 08-19-2019, 07:56 AM   #7
L78toLT1
L78toLT1's Avatar
Drives: Hyper Blue 2016 2SS 6M
It should also be noted that, the exhaust mode occasionally "disappears" from the screen on NPP equipped cars. Mine has only done this once in 18K miles, but some apparently do it more often. There are several related threads on this topic.
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned
L78toLT1 is offline   Reply With Quote
Old 08-19-2019, 08:28 AM   #8
blackgloves
I don't know what NPP, MRC, stands for
Current:
1987 IROC Z28
Former:
2019 2SS (Crush)
1978 Z28
2006 SS/SC Cobalt
2001 Z28
1972 Z28
1984 Z28
Old 08-19-2019, 08:45 AM   #9
HartfordRacingCaptain
HartfordRacingCaptain's Avatar
Drives: 2017 Camaro 1SS, 2023 Colorado Z71
User Gunkk replied to your other thread this morning with the ordering guide that contains all acronyms:
https://www.camaro6.com/forums/showthread.php?t=560563
NPP is the dual mode exhaust (4 tail pipes), MRC is magnetic ride control (upgraded suspension)
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow
HartfordRacingCaptain is offline   Reply With Quote
Old 08-19-2019, 08:46 AM   #10
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
NPP is the option code for dual mode exhaust.
MRC = Magnetic Ride Controll
overdriv is offline   Reply With Quote
Old 08-19-2019, 10:11 AM   #11
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
2019 2SS
Thanks in advance
If your SS has the quad tips, select settings on your screen, driving modes, engine sound management, select which mode you want.
1hprush is offline   Reply With Quote
Old 08-20-2019, 12:21 PM   #12
Mighty Mouce
Banned
Drives: Camaro
Pretty sure it comes standard with all 2SS's.
Mighty Mouce is offline   Reply With Quote
Old 08-20-2019, 01:01 PM   #13
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
No, dual mode exhaust is not standard.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 08-20-2019, 01:21 PM   #14
blackgloves
Mine doesn't have dual exhaust mode. It has 1 tip on both sides
Current:
1987 IROC Z28
Former:
2019 2SS (Crush)
1978 Z28
2006 SS/SC Cobalt
2001 Z28
1972 Z28
1984 Z28
