08-18-2010, 10:16 AM | #1 |
Drives: 2008 G8 gt / 2010 Camaro L99 Join Date: Oct 2008
Tune Time Stage 2 + 12psi
Just wanted to post a link to our shop car build , Keep in mind the Meth was an after though [ we just put it all in the trunk, High IAT's + a dead line for super chevy ... lol ] We also used our twin pump return fuel system .
3:73 and some good air and we should see some low 10's ... 60ft was a 1.81 and still with stock stall and trans ... Lookin for 9's on the stock bottom end in NOV FYI our 630whp [ mustang dyno ] has some big trap speed vs some of the 700+ [dyno jet] cars if seen ... http://www.superchevy.com/technical/...ger/index.html Last edited by Matt TuneTime; 08-18-2010 at 03:10 PM. |
08-18-2010, 12:10 PM | #2 |
Drives: First 9 inch-12 bolt IRS Camaro Join Date: Jun 2009
Great results Matt!! Parts leaving today!!!
08-18-2010, 03:09 PM | #3 |
Thanks Tom,
08-19-2010, 06:41 PM | #4 |
huge gains from no meth to meth injection. i am capped at 580 rwhp at 5.5 pounds of boost. I can either get a smaller pully or try some meth. I think if i 3.4 pully i need to address the fuel anyhows.
08-19-2010, 07:55 PM | #5 |
Drives: C63 P31 Join Date: Feb 2010
This car has all the right parts to be very fast. Great times with the Pro Charger.
08-20-2010, 01:17 AM | #6 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
9's on stock bottom end would be sweet. Good luck. Just get that car to 60' and it will be doable.
08-20-2010, 10:35 AM | #7 |
I'm working on it [ Ever watch a 6l80e go down the track with any Stall it seems to shift 2 times before it shifts to second [ Some will confuse this with wheels spin ] ] We are working on a solution with this and should see a good reduction in 60ft ...
08-20-2010, 08:40 PM | #8 |
Petro-sexual
KUDOS on the build I got that issue a bit ago and enjoyed the article. I'm left with a question about the high IATs, though...
Why are they so high? This doesn't sound like a lot of boost, so is it just because of where the intake is, or the S/C itself, or something I'm not even considering? Thanks, and great build. I've enjoyed all the tech' stories I've seen you in, especially GMHTP
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
08-21-2010, 08:49 AM | #9 | |
08-21-2010, 09:14 AM | #10 | ||
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout 2011 2nd Place Fastest 4 5th Gen LSX Shootout |
08-21-2010, 10:26 AM | #11 | |||
Listen to this Thats not wheel spin it's the trans adapts seeing the slip ... |
08-21-2010, 10:49 AM | #12 | ||
2012 ZL1 #1278
08-23-2010, 08:35 AM | #13 |
We just go our test unit from PI ... I will post up our findings ... Using on our 740 whp G8 first
08-23-2010, 08:49 PM | #14 | |
Similar Threads | ||||
Drawbacks of a mail order tune | herkman | Tuning / Diagnostics -- engine and transmission | 19 | 06-10-2010 09:58 PM |
Phaste Performance 'Stage 1' upgrade - CAI, shorties, axle-back & tune! | Sean@Phastek | V8 Bolt-Ons & Tunes | 1 | 03-17-2010 01:21 PM |
Tune Time L99 Stage 2 | Matt TuneTime | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 01-23-2010 06:52 PM |
Supercharger tuning: Why shop tune instead of tune with the S/C? | JProberts | Forced Induction - V8 | 10 | 12-28-2009 03:54 PM |
Undetectable Tunes - What You Should Know | kelley@vectormotorsports | V8 Bolt-Ons & Tunes | 159 | 09-18-2009 02:18 PM |
