09-10-2011, 08:00 PM | #1 |
Drives: '10 Camaro LS - M6 Join Date: Mar 2010
Overfilled by 0.28 quart
I mistakenly added 6.28 quarts of synthatic oil to my v6 instead of just 6 quarts. Should I be worried? :(
And if the extra 0.28 quart has to be removed, is there a way to do it with maybe a pump from the dipstick or filter without getting under the car?
09-10-2011, 08:45 PM | #2 |
knows 2 facts about ducks
I wouldn't worry about it
09-10-2011, 08:46 PM | #3 |
Drives: 89 IROC 350 Join Date: Mar 2009
did you check the oil level on the dipstick? Is it WAY over the full mark? If not, youre fine. YOu ever checked/changed oil before?
09-10-2011, 09:34 PM | #4 |
I'm not sure about this, but I think a quarter quart is about what the oil filter holds and may not be included in the change capacity. I'm just spitballing. Either way I wouldn't be worried.
09-10-2011, 10:12 PM | #5 |
i like to go fast
Drives: 2011 SS Join Date: Sep 2010
Warm up the engine. Turn it off and let it sit for about 3 minutes. Check the dipstick. If it isn't foaming, then you're OK.
09-11-2011, 02:04 AM | #6 |
I don't trust our dipsticks because it's hard to get a consistent reading. But the level seems to be in the middle of the upper cross-hatched area. From looking at the little oil on the dipstick, it doesn't seem like the oil was foaming.
09-11-2011, 09:00 AM | #7 |
Drives: 07_tundra/08_zo6 Join Date: Jun 2009
Your good to go oil changes are not an exact sience and six may have put you on the low side based on what you have stated.
09-11-2011, 04:03 PM | #8 |
Thank you all for your input.
09-11-2011, 04:55 PM | #9 |
Drives: 2011 Camaro RS M6 Join Date: Jan 2011
How in the world did you calculate .28 qt over filled?
After it has been ran, let it sit for an hour or so and check the oil. As long as it isn't above the bulged section of the dipstick, you should be fine.
09-11-2011, 04:57 PM | #10 |
Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
I wouldn't worry. 0.28 quarts is not that much. Dealerships usually overfill them by a lot more when they do it.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." . 2022 1SS 1LE (Coming Soon) |
09-11-2011, 05:13 PM | #11 |
just make sure on the dipstick that you are not way overfilled. Overfilling (WAY OVERFILLING) is just as bad as not running any oil at all... You could have the connecting rods slapping into the oil etc if the level is too high and this can cause catestrophic failure (NOT COVERED BY WARRANTY). (I am assumning you got one of those 5.28 Quart jugs and then just added a quart?) If so you are more than likey okay, but double check anyway...
09-12-2011, 11:56 AM | #12 |
Yup, I got a jug from Autozone and didn't notice that while Walmart sells 5 Quart jugs of Valvoline SynPower, Autozone carries 5 Liter jugs, which is equal to 5.28 Quarts.
Similar Threads | ||||
Like New - MB Quart DSC 1500.1 Class D Monoblock Amp [dsc1500.1] | xxlbeerz | Audio / Visual / Electronics/ Gauges / Nav | 3 | 12-18-2010 10:08 PM |
Mobil 1 $4.00 a quart at Pep Boys until 11:00am | BAD DAB | 5th Gen Camaro SS LS LT General Discussions | 2 | 11-26-2010 03:24 PM |
Mobil 1 $4.00 a quart at Pep Boys until 11:00am | BAD DAB | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-26-2010 08:06 AM |
