01-09-2014, 09:27 PM | #1 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Boost controller or no boost controller???
Simple question, yes or no for an 1100 rwhp street car that will see the occasional road course and spirited back road driving in north Tx. Will be twin turbo running PTE6766s at 20-22 psi and about 1100rwhp
Been looking at the Eboost 2 for simplicity but am eyeing the AMS-1000 since it seems to be a great unit with more features than i will probably use. But its nice knowing those features are there if needed. So, yes or no on boost controller. I always thought the right foot was a pretty good boost controller
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
01-09-2014, 09:44 PM | #2 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Be crazy not to have one. No sense in going turbo if you're not gonna use one. That's won of the perks of a turbo setup.
01-09-2014, 09:49 PM | #3 |
Drives: 2010 2ss/RS 4l80. 2009 2500 HD Join Date: Mar 2009
Heck yes. It would be great for dialing in or out of boost.
Heck I am thinking of throwing on a waste gate and boost controller on my D1sc set up
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379 FNSS Racing! |
01-09-2014, 11:14 PM | #4 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
Installed mine a few days ago. Haven't had a chance to play with it yet. Hoping I hooked everything up properly.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
01-09-2014, 11:22 PM | #5 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
On my D1SC wastegate, I won a True Street index with three runs averaged to within 0.007 of my target.
So, any type of dial-in, it really helps. Not to mention, with your setup, you might want to have presets for "Sane" and "Insane". Padre |
01-09-2014, 11:41 PM | #6 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
Without the boost controller, you know where you're gonna stand in the power sense. You don't know how tame it'll be on the streets. With the boost controller you can dial the boost down to a more manageable level for every day driving. I would get it.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
01-10-2014, 02:00 AM | #7 |
Drives: 2009 ZR1 Join Date: May 2010
Yes, definitely get one Bull. Eboost2 here also.
01-10-2014, 09:39 AM | #8 |
Yeah, I'm definitely going to have one. For some reason my shop is recommending against one, or saying it isn't necessary. If it makes the setup better than i think it is necessary
Now time to decide between Eboost 2 or AMS-1000 and get smart on the system
01-10-2014, 10:04 AM | #9 | |
Fabricator
Drives: 2011 2SS Summit White Join Date: Jun 2011
Having a boost controller helps everywhere. It can make the car way more user friendly.
Roto-fab CAI
Unobtainium Welding Exhaust ARH LT's 393whp L99 GPI VVT Turbo Cam-in |
01-10-2014, 10:13 AM | #10 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
the nicer electronic ones can even help spool time. Tested this theory on my Turbo buick years ago. Ended up using a HKS EVC EZ. Spool time was way less that with a halman type or turbonetics type manual set controller.
-John S.
01-10-2014, 10:31 AM | #11 |
Fabricator
Yes, one of the biggest advantages for sure.
Roto-fab CAI
01-10-2014, 10:48 AM | #12 |
50 Shades of Prey
Drives: TT/SS Join Date: Oct 2010
I have the eboost 2 and love it. Also I wouldn't wan't to be stuck at 1100 whp all the time.
Futral Motorsports built and tuned
01-10-2014, 11:15 AM | #13 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
My understanding is the minimum setting you can set your boost is your wastegate spring pressure. If you're wanting less boost then you have to change out those springs to lessor ones (nominal cost). You can then set your boost controller to a less boost value (only down the the spring pressure), and all the way up to your boost controller/turbos output boost capability. Gives you the range then.
I had to do that with my Tru-Boost controller to get a "wifey" mode in there.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
01-10-2014, 11:23 AM | #14 |
Not quite like that. You can usually go ~2.5 spring pressure depending on system, etc. You can't put in 5psi springs then hope to hold 30psi with a boost controller. Typically I would go with the rule of 2x. Run 12psi springs and have good control up to 24psi. Run 7 to 14psi or so as a general rule of thumb. That is way conservative though. 7psi springs probably fine to 18-19psi.
Nick
Corvette Z06 -1200ish rwhp |
